The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Is the machine operating properly, or are your clothes getting a musty smell?
The musty smell has a few solutions, One may work but probably a combination of all will work best.
Immediately move wet clothes to the dryer, do not let them sit in the washer for a long time. If your clothes smell, put mouthwash with your clothes directly in the tub during the wash cycle (this will not stain your clothes) leave the door open when not in use (lets it dry out) If the washer smells, use bleach and hot water in an empty cycle once in a while (kills just about every kind of bacteria or mold which may be causing the smell) Use washing machine cleaner once in a while(can be found at your local grocery store isle next to detergent) Dry your clothes completely, damp clothes can start to smell again.
If you are looking for a new washer, try to find a newer model that features a stainless steel tub with silver impregnation. The silver is a natural disinfectant.
When a moldy or musty smell develops in a washing machine, many times
the smell is coming from the open areas of the agitator. Water along
with soap and/or liquid softener sometimes splashes into an open
agitator, and when the lid is closed it does not dry out. Instead, mold
begins to form, and a musty smell wafts from inside the machine, even
after the lid has been opened for an extended period of time. Until the
mold is removed the washing machine will continue to smell bad, even if
it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect
in the holes, and when it does not dry fast enough it ends up smelling
musty and moldy. Even the top of the rim can become moldy and musty, but
proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
Hi, It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer. Thank you !!
If you don't leave the door open after each use you will get a musty smell and mold will build up in the bellows. also you need to wipe the bellows dry and the door glass dry as to not get a build up of soap residue on it which will eventually make the door leak. Also, only use one or two tablespoons of soap, not what the soap manufacturer says on the package.
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet. If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others. You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
if it is a Maytag neptune YES that sound is normal. especially when you rotate the drum by hand that is your balance ring you are hearing. Do you only use liquid detergent? if yes this might be your problem. it leaves a film around the drum. i would run 3 wash cycles with bleach and hot water. and then at least once a month with hot water and bleach to keep it fresh and also leave the door open so that it can air dry oder causeing bacteria love moisture.
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
the musty smell is from the door boot or gasket. deposit from clothes and detergent get trapped in there and have nowhere else to go. i would recommend purchasing Washerfresh tables to get rid of the deposits. they are available all over.
