The basic things that cause this problem are easy to troubleshoot and solve.
1. The humidity extraction level is set to HIGH. Lower it to 35% or less.
2. The air intake filter is dirty or clogged. Remove and clean the filter following the Owner's Manual's directions on "How to clean the filter."
3. Not enough clear air space around the unit. Maintain a minimum of 12" Clear Air Space on all 4-sides of the unit.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. If the unit is a basement, the air temperature at the floor level is colder than the air temperature at chest level. Place the unit on a sturdy table or counter, that can handle the weight of the unit, plus a full tank of water.
5.. Do Not operate the unit in direct sunlight. Close curtains or blinds as necessary.
Troubleshooting the 5 things listed above should help you solve the problem. Please let me know. Thanks.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
heatman101
