20 Most Recent Frigidaire FAD704TDD Dehumidifier Questions & Answers
The problem is that the hose connection tube that the hose is connected to, is clogged. That's the reason water was going to the bucket and the full bucket sensor was shutting the unit OFF
To unclog the tube, you will need an 18" long Plastic Zip Tie or something similar (NO Wire Coat Hangers, though) that is appropriately sized to fit into the hole. Before doing anything, Turn the Master ON/OFF Switch to OFF and unplug the unit.
Carefully insert the Zip Tie into the hose connection hole/tubing and continue to gently push it in, until it reaches the bend in the tubing. You will need to gingerly work past this bend, until it bottoms out or you run out of usable Zip Tie. Now, slowly remove it, while rotating it. This will dislodge the clog. As the Zip Tie is almost totally removed, be prepared for some water to follow.
The above should solve your problem. Will you still need the wiring schematic to reconnect the bucket safety switch? If so, please let me know.
Frigidaire... | Answered on May 28, 2011
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
0-
Frigidaire... | Answered on Mar 07, 2011
the hose mignt be cloged or obstructed in some way.take it off completely and try to blow through it.
Frigidaire... | Answered on Oct 08, 2010
Frequently the problem here is simply that the air flow is restricted. The solution is to thoroughly clean the hot radiator. It does tend to clog up.
Also it does freeze up if the ambient temperature is not sufficient.
Frigidaire... | Answered on Sep 12, 2010
i don't know. be careful with electricity. if possible, try running normal washer load along with your dryer but with [no heat] 'cold air only' to see if they will keep running.
if they run OK, consider shutting off both washer and dryer. shut off main electrical panel and change fuses for both washer and dryer. turn hydro on and run both again
with your normal settings. if they fail again please call for repairs. my dryer would not run and although everything looked and tested out OK, i had to replace a small 6x8"
electrical box having 2 only 30 amp screw in fuses.
then it ran OK.
Frigidaire... | Answered on Oct 02, 2019
if you fol;lowed all instructions and removed shipping braces then return for replacement or refund
Frigidaire... | Answered on Aug 25, 2019
Richard?
I have provided you a website that may help.
There has been a recall since 2013. Here below is the website.
My advice. Contact Gree. Be persistent and kind. Customer Support Reps, being people, can do wonders sometimes when they are treated kindly.
https://www.cpsc.gov/Recalls/2013/Gree-Recalls-12-Brands-of-Dehumidifiers/
Frigidaire... | Answered on Jun 16, 2019
Does it run after you get to the optimal humidity level?
If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
Frigidaire... | Answered on Feb 13, 2019
Good Afternoon Friend,
I understand you are looking for the owner's manual for your Frigidaire dehumidifier, model# FDL50S1. Attached is a link to your manual. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Frigidaire... | Answered on Dec 14, 2018
To remove the back cover, first remove the sides: two screws at bottom of side, one halfway up the back, one inside bucket opening. Also remove four screws holding the top on. Top slides forward to release, then sides slide up about 1/2 inch and pull straight out. Hooked into the front and back. Once the sides are off, the back will come off with remaining four screws.
Frigidaire... | Answered on Oct 19, 2018
Frigidaire FAD704TDD Dehumidifier Logo
Popular Tags
10 questions posted
Top Frigidaire Dehumidifiers Experts
Nestor Dede
Level 1 Expert
Your Consultant
Gil Shultz
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dehumidifiers
Most Popular Question
unit icing up
  • Dehumidifiers
