20 Most Recent LG LHD45EL Dehumidifier Questions & Answers
I have the exact problem with my LG LHD45EL as lubbock51's Aug 17, 2010 question. (see below) Isn't there anyone out there that's had this same problem and resolved it. I too am afraid to pry the grill for fear of breaking it...it made out of plastic so it won't take much to break the grill if I did.
By lubbock51 on Aug 17, 2010
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic in fear of breaking it. Any suggestions?
LG LHD45EL... | Answered on Jul 12, 2019
I believe it is a water tank code. Re-seat the tank, unplug wait 15 seconds and replug the power cord and see if this resolves the error.
Background relating to other possibilities.
When the water bucket reaches its capacity, the bucket switch opens to shut off the dehumidifier. If the bucket switch fails while it is open, it will prevent the dehumidifier from running. To determine if the bucket switch is defective, use a multimeter to test it for continuity. If the bucket switch does not have continuity, replace it.
LG LHD45EL... | Answered on Sep 17, 2017
It can be recharged but you would first have to locate and fix the leak and then refill. Then add a schraeder valve and refill at the port till suction line is cold to touch and starts to sweat. That's it!
LG LHD45EL... | Answered on Sep 09, 2017
A dehumidifier works like a low powered air conditioner where a fan draws air through a refrigeration unit which cools it and condenses water vapour and collects it in a container.
There is likely to be at least one air filter so some cleaning of the air takes place and such filter(s) will need attention periodically and in addition most manufacturers claim their products need servicing every 3 years.
Best results will be obtained when the room is closed and ventilation minimal and the capacity of the machine is more than adequate for the space where it is sited. A room with an open window or where the door is opened frequently is not really a suitable site for a dehumidifier.
It is important to choose a machine that is somewhat too large as efficiency will fall between service intervals.
It is quite possible a manual for a different but similar model by the same manufacturer will provide some useful information...
LG LHD45EL... | Answered on Jun 18, 2017
Try Googling (LG)(LHD45EL)(manual) without parens.
LG LHD45EL... | Answered on May 26, 2017
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
LG LHD45EL... | Answered on Dec 02, 2016
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
LG LHD45EL... | Answered on Aug 13, 2015
I own this dehumidifier. To connect it to a garden hose for drainage you first need the special connector pipe/adapter that comes with the unit. It's white plastic and about a foot long, It may be stored in the top of the bucket drawer, where it ships from the factory. Your hose connects to the threaded fitting on one end. The other end is inserted into the hole in the back of the unit. You slide it straight in until it mates with a drain connection inside the unit. You can see this black pipe connection if you pull the bucket drawer all the way out and look in the very top right hand corner of the opening of the unit. Once the white tube is fully and correctly inserted you'll find two plastic tabs on the tube near the hose connection. The larger tab points straight up and blocks the tube from being inserted too far. The smaller tab points down and hooks into the slot in the bottom of the round opening to keep it from getting knocked loose. Your dehumidifier should now drain through the hose instead of into the bucket. Of course, be sure your hose is routed across a floor to a drain or sump pump located lower than the unit, since the water flows by gravity.
LG LHD45EL... | Answered on Jul 01, 2015
If the water bucket has not been emptied the until will not start. If it has, be sure that the bucket was reinstalled properly in the holder and is making contact with the Water Level Control Switch on the back wall, inside of the bucket holder. The bucket should be installed "squarely" into the holder from top to bottom. The bottom of the bucket should not tilt down at the bottom when installed properly.
Hope this helps and thanks for choosing FixYa.
LG LHD45EL... | Answered on Jun 05, 2015
Put it on the min. setting.
LG LHD45EL... | Answered on Oct 19, 2014
looking at the back of the machine there is a plastic female hose connection just above the top of the reservoir.
LG LHD45EL... | Answered on Sep 20, 2014
The lower the number the dryer the air will be. 50 will provide a comfortable room.
LG LHD45EL... | Answered on Aug 03, 2014
LG LHD45EL Dehumidifier Logo
359 questions posted
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
motor runs dehumidifier but doesnt
  • Dehumidifiers
