20 Most Recent LG DH30 GoldStar Dehumidifier Questions & Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
LG DH30 GoldStar... | Answered on Nov 02, 2016
I had this problem, so have a few people. Solved by replacing big yellow capacitor on circuit board inside. Instructions here: http://www.howtomendit.com/answers.php?id=358398
LG DH30 GoldStar... | Answered on Aug 13, 2015
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
LG DH30 GoldStar... | Answered on Nov 10, 2013
you probley need to cleen the condensor coil
LG DH30 GoldStar... | Answered on Jun 18, 2013
Push through the membrane with the drain connector. The membrane has a circular cut almost all the way through it, and pushing at it with the drain connector will pop out the little hole. I've done it with four LG units.
LG DH30 GoldStar... | Answered on May 04, 2013
Unfortunately this is quite common for most DH's of this type. The only one that I have found that does not have a reputation for losing the fan or compressor after a year or two is the Whirlpool.
LG DH30 GoldStar... | Answered on Aug 16, 2012
Call sears see if the compressor is under warranty
LG DH30 GoldStar... | Answered on Jun 08, 2012
first check outlet, some have a killer switch at base of unit, and if not setting level will not turn on.
LG DH30 GoldStar... | Answered on Sep 30, 2011
The problem you're having can be caused by a couple things.
1. The float valve in the top of the water collection bucket is broken or is stuck in the Down position.
Remove the bucket, and inspect the float valve for damage or sticking. If it's stuck in the DOWN
position, jiggle the arm of the float valve, to make it works freely.
2. The water collection bucket is not installed properly and water is leaking out the back of the
top of the bucket. When installing the bucket, be sure it's installed "squarely" into the bucket
holder from top to bottom and making firm contact with the bucket safety removal switch on the
rear wall of the bucket holder.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
LG DH30 GoldStar... | Answered on Sep 15, 2011
LG DH30 GoldStar Dehumidifier Logo
78 questions posted
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
delonghi dem 10 dehumidifier stopped
  • Dehumidifiers
