Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
Posted on Jun 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our Samsung front loader is leaking small amounts of water into the pedestal each cycle. The door seal does not seem to be leaking and the water is draining from the washer. Any thoughts?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3387
Points
The rubber came loose and the metal ring that holds it came off. How do I reinstall this ring?
gdockery
Level 1:
New Friend:
  • Posted on Sep 02, 2012
gdockery
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3387
Points
Ours was leaking from the place you put the detergent and softner, it leaked into the door and the inside of the door filled with water, causing it to leak into the drawer below it. We have totally cleaned out the tray area, used a tooth brush to clean the holes out, don't know if that is going to work, but that is where we are at the moment....
Anonymous
Level 2:
New Friend:
  • Expert 32 Answers
  • Posted on Jun 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
32
Questions
0
Helped
10136
Points
100
The door rubber tends to perish, you need to check the rubber on the door or try to move the current bottom of the rubber seal to the top, the machine does not fill up more than 50% of the rubber area.
Anonymous
Level 1:
New Friend:
  • Posted on Aug 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3387
Points
I am having the same problem. It is NOT leaking from the door. Both solutions listed talk about the door leaking. Did you ever find out why your washer was leaking?
  • Anonymous Dec 14, 2011
    Did you ever get this fixed? We are having same issue now.
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
1helpful
I have a two month old Samsung WF350 front load washer. I have a trickle of water leaking from the bottom of the door during wash cycles.
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
1helpful
1helpful
3answers
Hi there... My Whirlpool Duet washer has recently sprung a leak! It leaks a small stream of water out of the bottom left side (as you would look at it from the front) and runs down the stand to the floor....
I had the exact same problem on my Whirlpool front loader (model# GHW9100LW1). It turned out to be a tear in the rubber drain hose (from tub to pump). There seemed to be some debris caught up in the drain hose, and what really did the damage was a piece of metal wire that broke off one of my wife's bra straps and made a nice tear in the hose. The washer leaked out of the left side as well and down the pedestal. The drain hose only ran about $13.00. To get to the hose you will have to remove the front tub seal (bellow) and the panel just above the pedestal. While you're in there it would be good to clean out the filter cap for the drain pump as well. Good luck!
3helpful
My Whirlpool front end loader washing machine is leaking from the degergent dispenser.Also, when it is on the spin cycle, it makes a load noise and it will occasionaly leak from under the door.
We just had the same problem. After taking out the detergent tray, we saw the water was not draining into the drum. Feeling around the door seal in the upper corner (there is a small opening all the way around, between the door seal and drum seal, that you can fit your fingers into - please unplug your maching), my husband felt some fabric, and pulled out a mangled toddler pillowcase, which would have been in there for about two - three loads prior to finding the leak. Odds are you may have some medium size fabric piece in there, and is likely is the blockage. This is where the water seems to drain from the detergent compartmemt to the Drum.
Tromm Washing Machine small leak
Front load washers will always have some water in them. if, it leaking out, you may either have a bad seal, these are double drums, you may have a leak at the discharge house coupling at washer
1helpful
Front door leaking during washing cycle
There are only two ways that water can leak out this way. it can be either the door seal or the door lock mech has become misaligned, causing a slight gap that is letting the water escape through.
I recommend inspecting the door lock mech for its integrity. make sure it is aligned correctly to specs. replace this mechanism if found to be faulty or misaligned. i would also inspect the seal for tiny ruptures as well. the slightest rupture or hole can allow small amounts of water to excape.
Inspect these areas thouroughly.
1helpful
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Water leak at door but seems to come from door itself.
no seal in outer door, but that's what you need outer door frame about 300.00 , labor 152.00 buy service smart agreement from sears it will cover parts put to 500.00 it will fix it "less soap plz"
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
