Gas dryers have an ignition panel that gets hot and when it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer. If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes. Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Common faults - 1 Theheating elementscan fail
(meaning open circuit) 2 There arecut-outs (T.O.C's)that
might need resetting 3 Thethermostats (stats)can trip
out or burn out (meaning opencircuit) 4 Moderntumble dryers also have sensors andpcb's (Printed circuitboards)thesehave
programs that can fail and circuitry although most should produce an errorcode
showing you were the fault is. 5 Faultyconnections and burned wires may also be
the fault.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
