20 Most Recent
Samsung DV218AEW Electric Dryer Questions & Answers
My brada dryer model #
Mine was doing same. Code t0. Open door and hidden by lint trap is the moisture sensor. It's in worst place possible 2 metal bars attached to pink and orange wires. Looking at dryer on lower right. Clean these of lint and problem solved.
My dryer stucks at 1 minute and runs forever
I have the same problem with my Samsung electric dryer DV339AEG/XAC. It stuck at 1min cooling forever even though the clothes were completely dried.
I solved the problem after researching online. The heating coil inside the heating element was touching the metal casing. The ceramic insulation was not holding the coil in place in one of the sections, and the coil touched the casing at that point.
I repositioned the coil to allow better separation which essentially moved the coil further away from the casing. Once that's done, the dryer can count down passed the 1 min mark and automatically end the drying cycle, as expected.
No need to change PCB, or humidity sensor, etc.
I tested it before and after the repair using an ohm meter. The resistance across the terminals of the heating element should be approx 10 ohms but no connectivity to the casing. Before the repair, it was reading 5 ohms between 1 of the terminals and the casing. Same reading for the other terminal. Once fixed, neither terminal registered any reading on the ohm meter with the casing, the way it should be.
Make sure you unplugged the dryer from wall outlet before servicing it. A certified repairman should know what I was talking about.
Good luck.
Dropped my wedding ring down
You could spread a sheet on the ground and ask a couple of strong neighbours to try and shake it out...
The alternative is likely to be an almost complete dismantling of the dryer.
It wouldn't be wise to use the dryer until the ring has been recovered due to the possibility of it shorting the electrics...
Samsung dryer issue
Do NOT up amps on fuse, needs only 30 amp fuse, more than that risk of fire. I would replace power cord with new one hardware stores carry them. If old cord plug pronges are burnt, or discolored, should be bright color of brass not dark. Then check terminal block in back for same condition.
My 2-year old Samsung electric
need to take off front of dryer.
to disassemble:
1. take off top.
2. remove control panel.
3 remove screws holding front on.
