Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
SOURCE: jura capresso
The dial on the upper right is all you need to do. Turn from the coffee cup to the water symbol. Water will pour out the spigot from the frother wand so put a cup under it. Close the tap when prompted by turning the dial back to the cup symbol
SOURCE: my jura capresso says system fill...it makes a lot of noise
System fill is usually when the machine auto solenoid fill valve is putting water into the boiler. If it is making noise then the solenoid is clogged or there is no water getting to the solenoid.
SOURCE: I have a Jura Capresso Impressa S9 and it keeps
try this:clean with brus two metal contact on drip tray
Same thing happened to me. I just got a C5 for Christmas. After a quick rinse, the power shuts off and then won't go on again for hours. Any ideas?
