Garden Logo
Posted on May 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
Roy Cagle
Level 3:
President:
  • Master 1,545 Answers
  • Posted on May 06, 2011
Roy Cagle
Master
Level 3:
President:
Answers
1545
Questions
Helped
913898
Points
4781
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
2helpful
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 • Garden
2answers
I am trying to replace the head on my TB575EC trimmer but can't remove the black inner spool. Any suggestions?
Unscrew the head's center bump-knob counterclockwise with your fingers. Pull the bump knob off and take the spool cover off the head. Slide out the spool and any remaining cutting line. Lift out the spring underneath the spool. Take out the slide washer. Unscrew the arbor bolt either clockwise or counterclockwise, depending on model, in the center of the trimmer head using the wrench. Take the entire head off the end of the shaft.
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
2answers
Does Toro still make 88035 spool cap replacements? I cannot find them anywhere.
According to this large online parts distributor, that part has been discontinued.
http://www.partstree.com/parts/?pn=88035
I found this one on Ebay....it looks like the spool with the knob for a 10" electric trimmer. I tried!
http://cgi.ebay.com/TORO-PREWOUND-SPOOL-ELECTRIC-TRIMMERS-PART-88180-/280505426528?pt=LH_DefaultDomain_0&hash=item414f6d2260
How do you get the spool off of a gas (31cc) ryobi weed wacker? The string is stuck up in the spool and I can't get it out.
The knob on the bottom unscrews, and the spool comes apart once you get that off.
Mar 27, 2010 • Garden
1helpful
How do you change the pull rope on a poulan 31cc gas trimmer
You have to take the unit apart. Seperate the shaft from the engine. Then take the engine off the back side. This will allow access to the starter spool, where the rope goes. If you get that far, be careful when you wind the spring. Good luck...Lee
2helpful
I need to know how to load a two string trimmer head. This is on a ryobi weedeater model 700r, 31cc, 15 inch.
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Aug 25, 2009 • Garden
1helpful
I have a robi 31cc don't know how to put on new string has double head i can't put the string on
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
9helpful
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
21helpful
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
