Computers & Internet Logo
Posted on Apr 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer some problem so i am formet my computer pci simple communicatio controller is not working display setting also not setting
Anonymous
Level 2:
Sergeant:
  • Expert 174 Answers
  • Posted on Apr 30, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
174
Questions
0
Helped
30574
Points
502
You have not mentioned the chip set of the board.
After formating the system, every device driver is to be installed. (Sound, Display, Network card etc)
2helpful
2answers
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
PCI simple comm controller
the PCI simple comm controller is part of the chip set drivers. You can find these at E-Machine's website, under support. Since you did not provide a model number I can not be more specific than that.
I tried to set up dual clones monitors and set the display too high for either monitor now i cant see to reset the video display. Is there a way to reset the card to factory setting with seeing the...
Hello dave, the only way you can change default setting on resolution is go to > Nvidia Control Panel > Display > Change resolution and click apply. If this option does not work you can go to start> control panel> uninstall a program and remove your old nvidia driver from you computer and reinstall latest driver again, restart computer. I hope this helps you.
I have an inncom thermostat in my room, and it keeps doing a thing where it will turn on, but only the fan, for about 3-15 minutes, then it will shut off. And I can only get the thing to turn on when it is...
if you set the t stat in VIP mode you can operate the fan manually but you shouldnt have to do this. it sounds like the t stat is losing communicatio with the HVAC reciever board.
I am using mercury 845gvml motherboard but having a problem in vga drivers
To set up vga you have to set the bios setting to the vga platform which you are using like intgated to on board ,pci to pci card and pci-E to pci express card .
Then boot pc and right click on my computer - manage-device manager-display adapter -and see any yellow mark in it .
if their is any mark then update the driver by keeping mother board cd in cd/dvd rom .
delete any non completable driver in it or you can use control panel to do this work .
if you are unable to boot in system then on boot screen press f8 to boot in vga mode or safe mode .and do all work recommended
2answers
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
4helpful
Asus EN7200GS
PCI simple Communication controller refers to a modem which is installed in your computer but with no driver installed.
Here is the web address for your graphics card:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Regards,
Graemevm
2answers
How to disable onboard/integrated video in bios
I would suggest attempting to configure it through windows. Go start, control panel, display and set the secondary output which should be your pci card to display the primary screen. If that does not work I would suggest going onto the hp website and searching for further assistance.
1helpful
2answers
Pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
4helpful
3answers
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Grand Canyon Tech
Grand Canyon Tech
