20 Most Recent EliteGroup 741GX-M Motherboard Questions & Answers
2answers
Necesito el? dibujo o el diagrama de la placa madre 741GX-M
english...english.
8/6/2014 5:14:13 PM • EliteGroup... • Answered on Aug 06, 2014
0answers
Manual diagrama
Be the first to answer 11/26/2013 5:43:04 PM • EliteGroup... • Posted on Nov 26, 2013Be the first to answer
What is the fastest AGP
Hi, it should be the nvidia gtx 400 series
these cards are used by gamers.
But they are difficult to find as new.
Most video cards today are socket PCI-E and
it does not fit your mainboard.
You can maybe look for a used one.
9/8/2011 11:47:00 PM • EliteGroup... • Answered on Sep 08, 2011
I have a 741gx-m motherboard
As long as you have a (recommended)350w power supply and, can connect the power cord supplied, the card will work fine for you.
5/23/2011 2:01:09 PM • EliteGroup... • Answered on May 23, 2011
I got a computer off
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd and the second and third boot device to cd press escape then press f10 to save to cmos to restart (note after you have loaded the operating system you must go back and change the first boot device to your hard drive) The BIOS is AMI. Under ADVANCED SETUP: The options listed for 1st,2nd ,3rd Boot device include: IDE-0 means Pri master ? IDE-1 means Pri slave ? IDE-2 means Sec master ? IDE-3 means Sec slave ?
hope this helps
5/4/2011 6:17:17 AM • EliteGroup... • Answered on May 04, 2011
My 741GX-M motherboard is much
if its overheating make sure al the fans are working especially the fan cooling the processor, also make sure your tower has no missing covers on the back where you can add different cards, if all is good buy some thermal grease> unplug all power sources to your unit, make sure its fully discharged, use an antistatic band if you have one if not touch the powersupply to make sure you have no static discharge, remove the fan on the processor, and apply the thermal grease on the processor, you should be able to see where the grease is at where the manufacturer applied it.
make sure your system is in a well ventilated area, sometimes in computer desk there is not much air flowing through it. I hope this helps, please vote if this was of any use thanks.
2/18/2011 2:52:16 AM • EliteGroup... • Answered on Feb 18, 2011
My 741gx-m2 motherboard produces continuous
reset your cmos see if this helps pull the jumper on the jp3 circuit on the motherboard and short the 2 and 3 pins with the power off and unplugged then put the jumper back to 1 and 2 ! the bios settings are wrong and this will reset the bios to defaults.
1/27/2011 11:44:21 PM • EliteGroup... • Answered on Jan 27, 2011
It seems no matter what i do i can't get any video
Good Morning
Have you considered the monitor you are hooking it up to might be bad?
It has happened to me before
Best of luck
11/26/2010 2:06:44 PM • EliteGroup... • Answered on Nov 26, 2010
I have a ECS 741gx-m system board in a system
Short answer: Yes.
Long answer:
First off you will need to have a computer with a working floppy drive as well as a working floppy drive in the computer that you will be updating. Once you have this you can update the BIOS by going to the manufacturers website, clicking on the Download tab under the picture and then on BIOS under the tabs. Read all the instructions that are available to you before actually updating including this PDF for using the flash update utility.
If you don't have a working floppy drive than you can still update if you already have Windows 98 or ME installed. Follow the instructions in this PDF, instead of the one above, and you should then be able to update the BIOS.
After you have updated the BIOS you will want to change the boot order listed in the BIOS so that you can boot the Windows XP CD-ROM. To do this start pressing the DEL key, you don't have to hammer on it just press it slowly, until you see a blue screen with a table in three sections with the top two containing about 13 choices. Use the arrow keys to highlight Advanced BIOS Features than press enter. You should then see a whole list of settings. Look for the three settings labeled First Boot Device, Second Boot Device, and Third Boot Device. Change each one by first highlighting it by using the arrow keys than by pressing either the +/- keys or the PGUP/PGDN keys. You should set them so that they show the following:
First Boot Device
[CDROM]
Second Boot Device [Floppy]
Third Boot Device [HDD-0]
After you finish changing them press the ESC key then the F10 key. You will be asked if you want to save your changes, press the Y key to save your changes and exit the BIOS setup.
Now that everything is set you can insert the Windows XP CD-ROM and install.
11/9/2010 3:30:23 AM • EliteGroup... • Answered on Nov 09, 2010
My video port on pc won't show any thing display
Restart the computer, and enter BIOS SETUP.
Ensure that the "onboard-video" is set to ENABLED.
Also, check the "priority" of video-adapters, i.e., "primary is onboard video" versus "primary is PCI/AGP video-card".
9/15/2010 3:52:17 PM • EliteGroup... • Answered on Sep 15, 2010
It goes off automatically
Enter bios and check your CPU temperature, maybe it gets hot (optimal CPU temperature depends on CPU type, but usually it? not normal if it? above 65 *C) and because of that shutdown occurs. If the CPU temperature is high, apply heating paste between CPU and heatsink. Usually if the PSU is defective, the system restarts, shutdown occurs rarely.
If this is the solution for your problem, please rate my post, otherwise give us more details aboutyour problem.
Regards,
Andras
9/13/2010 2:21:12 PM • EliteGroup... • Answered on Sep 13, 2010
Hi! i need Elite 741GX-M Motherboard and am in
I really do not know although you can see if these people will ship one out to you
http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=5&SRCCODE=WEBGOOCOMP&cm_mmc_o=mH4CjC7BBTkwCjCECjCE
6/28/2010 10:57:33 AM • EliteGroup... • Answered on Jun 28, 2010
Does the 741GX-M Motherboard have TV out function?
No it does not.
Mark
6/27/2010 2:22:17 AM • EliteGroup... • Answered on Jun 27, 2010
No audeo out
You need to install a sound driver I have attached a link that contains all of the drivers for *********** board.
http://driverscollection.com/?H=741GX-M&By=ECS%20%28Elitegroup%29
I hope this helped
Thank you,
Norse
5/19/2010 11:12:03 PM • EliteGroup... • Answered on May 19, 2010
EliteGroup 741GX-M Motherboard Logo
54 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
741gx m motherboard
  • Computers & Internet
