Duravit 0910100005 Happy D Toilet Cistern  - White Logo
Posted on Feb 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get the water supply hose, which is behind the toilet to connect with the water supply valve on the wall? Duravit says the back of the toilet is slightly curved, but I don't see how the water supply hose fits from behind and keeps the toilet tight to the wall. Thanks, Dave
leas debree
Level 2:
Habit-Forming:
  • Expert 25 Answers
  • Posted on Feb 20, 2018
leas debree
Expert
Level 2:
Habit-Forming:
Answers
25
Questions
Helped
6862
Points
165
Are the install correct ?I can't believe an install time frame where the technician is actually on time! Work was done quickly and efficiently. Definitely one of the best install experience I've had. Thank You.
Heated Toilet Seat Installation
5 Related Answers
stefano-61
Stefano Andreani
  • 69 Answers
  • Posted on Jan 05, 2009
SOURCE: How do i get the top off of my duravit toilet??
try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
Anonymous
  • 34 Answers
  • Posted on Feb 07, 2009
SOURCE: my duravit toilet keeps running
Sounds like the flapper valve on it. Let me know the model number and I can hok you up with more info on it
Anonymous
  • 119 Answers
  • Posted on Nov 15, 2009
SOURCE: How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Anonymous
  • Posted on Nov 17, 2009
SOURCE: maybe I'm an idiot but I don't know how to get the top off of my
If yours is like mine, which has the flush and half flush that make up a circle, do the following:
Press either the flush or half flush.
Lift up the other half. (It should come straight out)
Lift up the remaining half.
There should be a white plastic screw that you can then remove.
Hope this helps.
Anonymous
  • 5 Answers
  • Posted on Jul 02, 2010
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Good morning. when i set my washing machine to wash, it takes the water but when it must start to wash it drains all the water and say 4E. what does that mean
The first thing to do when you see the NF or 4E error code appear on your Samsung washer:
Step 1 - Remove the unit from power! Be sure the water supply valves on the wall behind your washer are fully open. These 2 water valves must be ALL THE WAY open to provide water to your Samsung washer. Turn them all the way counter-clockwise to be sure. If you have check valves on the wall, make sure they are turned all the way open and parallel with the water supply hoses. If both the water supply valves are fully open, proceed to step 2.
Step 2 - Check to be sure the water supply hoses are not bent, crimped, or kinked. If the hoses are bent, this can prevent water from getting to your washer. Be sure that when you last pushed the washing machine back towards the wall, you did not inadvertently get the water hoses crimped behind the washer, as this happens often. To be sure, get a mirror and a flashlight and look behind your washer without pulling the washer away from the wall. If the water supply hoses are bent or crimped, slide the washer out enough to get your hand down there to get the water supply hoses straight so the water can flow properly. If the water supply hoses are too short, replace them with longer water supply hoses so the water lines do not get bent when you slide it back into place. If the water supply hoses are not crimped or bent, proceed to step 3.
Step 3
- Be sure there is nothing clogged inside the water supply hoses. To check this you need to turn off the water valves that supply water to the washer. Unplug the washing machine from power or turn off the breaker. Slide the washer out far enough to get to the water supply hoses that attach to the back of the washer. Remove the water supply hoses from the back of the washer. (Keep the water supply hoses attached to the water valves on the wall) Be careful as there may be water mesh filters installed in between the water supply hoses and the water inlet valve. If so put these aside and clean if needed. Get a bucket and be sure the water supply hoses are not clogged by slowly opening the water valve one at a time and let the water flow into the bucket. If the water flows freely then the water supply hoses are not clogged. This is to test to be sure the water is flowing properly from the water hoses and valves. If the water does flow as it should from the water supply lines proceed to step 4.
Step 4 - Check where the water hoses were attached to the washer. You will need to pull the washer all the way out so you can get behind it. The part that the water supply hoses screw into on your Samsung washer is the Water Inlet Valve or Valves. Check the water inlet valve to be sure there is nothing clogging or blocking the water from entering. There may be small water mesh filter screens on the water inlet valve that could be clogged, clean if needed. If you do not see anything clogging the water inlet valve or valves, proceed to step 5.
Step 5 - The water inlet valve itself may be clogged internally, have a loose electrical wiring connection, or the solenoids in the water inlet valve are not operational. If you suspect the water inlet valve is faulty or has a loose connection, you will need to open the washer up to gain access to the valve. Remove power first. Check to be sure that the wiring harness is connected to the water inlet valves. Be sure it is secure and not loose. If the wire connection is attached to the water inlet valve, you may have a bad or faulty solenoid in the water valve or valves. At this point you could test them with a multimeter or simply replace it or both.
NOTE: SOME Samsung washing machines have 2 water inlet valves, 1 for COLD water and 1 for HOT water. Other Samsung washers have a hot and cold water inlet valve as one part.
2answers
Adjust the water level in the bowl of a duravit toilet
You can't. Water level is set by the design of the trap built into the ceramic base. Can only adjust height of water in the tank.
How to change water level ?
The level is determined by a floating device connected to the water valve. Some are on an angled arm and some move up and down.
Determine how your valve is shut off and either change the big round float or adjust the clips on the rising one.
Just keep the level below the overflow and the flush handle to avoid a running toilet or a leak.
How do I replace a fill valve in a Duravit Starck toilet?
copy and paste link
https://terrylove.com/forums/index.php?threads/duravit-fill-valve-inlet-valve.83232/
My w/c flush non stop water flow
You need to shorten the flush time of the flush valve.
2helpful
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
1helpful
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
2helpful
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
