20 Most Recent Duravit 111335001 Geberit In Wall Carrier for Wall Mounted Toilet Questions & Answers
0answers
0answers
0answers
0answers
Water continues to flow after
You may need to change your diaphram in your filler unit
9/1/2011 10:38:48 AM • Duravit... • Answered on Sep 01, 2011
My w/c flush non stop
You need to shorten the flush time of the flush valve.
8/29/2011 2:36:27 AM • Duravit... • Answered on Aug 29, 2011
Water level in bowl is too low so it's a problem
All toilet bowls have a preset water level determined buy the design of the internal s-trap and can not be change. However if the water level in the tank is not as high as it should be this will affect the water put into the bowel as the bowel in refilled by the flush valve and if it is set to stop before it get filled to the proper setting the bowl water level may be low.
A quick test is to see if the water level in the tank is up to the line in the tank most all toilet tanks have a line either stenciled or marked with a indentation in the porcelain. Another way is to mark the level in the bowel with tape or a marker then pour water slowly into the bowel not fast enough to flush it wait to see if it stays higher then the mark you made or settles back to that level.
2/4/2011 9:10:58 AM • Duravit... • Answered on Feb 04, 2011
My geberit in-wall toilet won't
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
11/29/2010 5:03:46 AM • Duravit... • Answered on Nov 29, 2010
Where do you find the serial # on a Duravit soft close toilet?
Depends on the model you have. Try the back of the unit or under the supply panel on the left side.
3/19/2024 6:22:20 PM • Duravit Home • Answered on Mar 19, 2024
Manual for Duravit toilet D11518
Contact Duravit or its distributor to request the manual.
3/29/2021 12:43:51 AM • Duravit Home • Answered on Mar 29, 2021
3answers
I have to keep replacing the flapper on my duravit toilet to stop it from constantly refilling due to leaking. Why is this happening? I replaced the last one 4 months ago. How can i prevent this?
Are you sure the flapper is dropping back down? Theflush handle may be sticking and holding the flapper valve up.
8/13/2019 8:24:28 PM • Duravit Home • Answered on Aug 13, 2019
I have a square soft closing Duravit toilet seat but the soft closing hinges are broke where can i hind the model code so i can purchase new ones
Try this link: https://www.happyisclean.com/Products-Duravit_Parts.html
12/16/2017 1:20:16 PM • Duravit Home • Answered on Dec 16, 2017
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
10/5/2017 4:34:53 AM • Duravit Home • Answered on Oct 05, 2017
Duravit 111335001 Geberit In Wall Carrier for Wall Mounted Toilet Logo
16 questions posted
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
View Most Popular
Duravit Home
  • Duravit Home
Most Popular Question
water continues flow after
  • Home
