The door handle on my GE GSS25QGTA has become loose. Its the right (refrigerator) side and the bottom of the handle has started to loosen. How can I tighten the handle? Thanks much, Ray Winberg
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
I just FINALLY fixed mine... Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door). That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them. It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
