20 Most Recent
Bosch Evolution 800 B20CS80SNS Stainless Steel Side by Side Refrigerator Questions & Answers
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Turn on ice maker
water is fine, change water filter already, but still no making ice, it get freeze and then became water again in Bosch B20CS80SNS
Ice maker turned off
Not sure about that model but many of these work the same....if you pull out the ice tray, you should see a wire/metal arm that may be in the fully "up" position - it would need to be turned down to enable ice making.
