Innovage Jumbo Remote Control Logo
Posted on Apr 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need code for AT&T Universe Cable and Sony Tv , and Sony DVD & Vhs Player, Also need picture of remote.
Anonymous
Level 2:
Sergeant:
  • Expert 189 Answers
  • Posted on Apr 14, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
189
Questions
0
Helped
31650
Points
588
I was unable to find the code for that specific cable box. The TV was no problem, And I couldn't find the combo code, but I have the Sony VHS code and DVD code. Maybe they'll work.
Sony TV: 002, 006, 071, 128
Sony VHS: 004, 099,128,139,140,141,147,154,155
Sony DVD: 009, 174
I hope this helps!
2answers
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
1helpful
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
3answers
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
1helpful
I have a goodmans dvd player and a samsung flat screen tv.when i try to play a dvd the picture is fine but no sound.
What type of cable are you using to connect the TV & DVD together?
You may also need to connect the 2 RCA(Phono) plugs for Left & Right Channel sound if you have used an S-VHS cable for the video link-up.
Cannot connect a VCR/DVD player to Zenith SY1959Y
you don't need a code for the vcr/dvd combo to work on your tv. You need to make sure you have hooked up the cables correctly. remember that the dvd can be hooked up with the component cabels and the vhs may need to be hooked up thru the tv cable hookup.
2helpful
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
1helpful
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
2answers
Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Top Innovage Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Innovage Televison and Video Expert? Answer questions, earn points and help others
