20 Most Recent Toshiba 32D46 32" TV Questions & Answers
How to change language to English
If you're lucky it only has active powered memory, unplug the tv and click the start button a few times to discharge, plug back in and go through the initial setup.
5/10/2014 6:52:00 PM • Toshiba 32D46... • Answered on May 10, 2014
2answers
Power button nor remote will
Hi, Please check your fuse and replace if blown
12/26/2012 5:50:18 PM • Toshiba 32D46... • Answered on Dec 26, 2012
TV will not turn on
This kind of problem occurs due to bad capacitor or devalued resistor in power supply section after long period of service, please replace bad electrolytic capacitors and devalued resistors in power supply and deflection section to solve this problem.
Capacitor and resistor replacement requires soldering work with proper tools and its job of technician, please contact local tv repair shop as any attempt to replace parts on circuit board by novice would caused more damage.
Hope these info will help.
Thanks.
4/10/2011 7:23:31 PM • Toshiba 32D46... • Answered on Apr 10, 2011
Is it possible to use your laptop on this tv ?
No,sorry this tv is a CRT-tube analog tv.Ur laptop require a LCD or plasma tvs to be able to used as a monitor.
1/3/2011 12:28:37 AM • Toshiba 32D46... • Answered on Jan 03, 2011
Toshiba 32D46 - Need to know weight in order to
Hello
Your Toshiba 32D46 model TVs weight and diamensons are
Width: 29-9/16 in. (751 mm)
Height: 25-15/16 in. (658.5 mm)
Depth: 21-3/4 in. (552 mm)
114.7 lbs. (52.0 kg)
OK
1/2/2011 3:06:15 AM • Toshiba 32D46... • Answered on Jan 02, 2011
2answers
Where is the Vertical I.C on a Toshiba 32D46? PICTURE PROVIDED!
on the back of the tube,is a yoke with two drive coils,on is vertical drive,and the other is horizontal.follow the plug to the pc board where it is labelled vertical in white writing.there is a chip with a number like ta7267. beside it are some capacitors and there is a 4.7 50 volt capacitor beside the heat sink.the heat sink heat dries them out
8/24/2010 2:05:32 PM • Toshiba 32D46... • Answered on Aug 24, 2010
There are only two channels ant 3 and ant 4. So I
first you have to set up to auto program . to obtain more channel to store. then go to AV to view on video channel. using dvd .
6/24/2010 10:32:45 AM • Toshiba 32D46... • Answered on Jun 24, 2010
Thin white horizontal lines across
This kind of thin white lines appear in picture tube tv due to weak/ dried up electrolytic capacitors in vertical deflection section.
Replace capacitors of vertical section (these would be 6 or 7) to fix the problem.
Let me know if you have additional question.
Thanks.
6/21/2010 6:29:33 PM • Toshiba 32D46... • Answered on Jun 21, 2010
Defective remote control
Try website like Remotes.com to buy a exact or very close to the original remote.
6/17/2010 5:31:12 AM • Toshiba 32D46... • Answered on Jun 17, 2010
Is this a high definition tv
this is not an HD TV
5/5/2010 10:43:00 PM • Toshiba 32D46... • Answered on May 05, 2010
Power supply button not getting on
Hello talwar,
Hi, the easy level would be to check for the following parts 1. fuse, if open, replace 2. faulty switch, check for continuity using a multi-tester device. 3. check open wire/power cable
if this cannot solve the problem.
this would be the hard part 1. If the fuse replaced, exploded again, check for shorted parts like regulators, diodes, capacitors. 2.the fuse is good but still no power, this is power supply failure, needs service. (there is too much explanation and testing involve)
call your local service shop for a job. thats it.
4/30/2010 7:26:16 AM • Toshiba 32D46... • Answered on Apr 30, 2010
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
as i've read you statement your tv need to check parts by parts, the one you mention upside trace vertical line, that part control on vertical ckt faulty parts nearly to faded filter capacitor you can directly replace all capacitor of vertical section. the one you adjust is that the playback transformer the upper portion is focus and the lower portion is screen voltage controlling screen voltage supply to crt g2 pin. if you turn this high that resulting hazing sound come from 2nd anode cup.
3/29/2010 11:01:23 AM • Toshiba 32D46... • Answered on Mar 29, 2010
Picture goes to a single horizontal line.
Your problem is due to failure of the vertical scanning circuits in your TV. This is quite common and is caused by aging components. Generally drying out capacitors
You got to be careful not to leave it on too long when the picture collapses, it will burn a permanent line across the screen.
If you are an electronics expert you can fix it if you get a schematic. If not please don't attempt to reapir it yourself since there is high voltage in side the TV.
The problem may get worse with time.
3/14/2010 12:05:30 AM • Toshiba 32D46... • Answered on Mar 14, 2010
2answers
Toshiba 32D46 - Will Not Turn On - White Lines Near Top of screen
I have the same problem with the same TV from Tosiba. I think Tosiba know about it but did nothing to repair it but sold millions of the same TV and Made good money. I think we all should soin togather and file a class action lawsuts against the company. They must fix the TV or pay our money back plus pay for our pain and suffering. There are many lawfirm will take this case and get paid from proceed. [email protected]
2/26/2010 6:09:36 PM • Toshiba 32D46... • Answered on Feb 26, 2010
HORAZONTAL TRACE OVERLAP AT TOP OF SCREEN
Usually that is caused by a part failure. The vertical deflection ckt is most likely the roblem. Sometimes it's just a cap usually a 100mf right next to the vertical ic chip. Or it can be the ic itself. Unfortunately you can't adjust it out.
2/23/2010 11:18:48 PM • Toshiba 32D46... • Answered on Feb 23, 2010
What is the best indoor antenna for a toshiba
Most indoor antennas are NOT very good, for good reception you really need an out door one, even if it is mounted out a window it will be better than the best indoor.
2/15/2010 5:40:32 AM • Toshiba 32D46... • Answered on Feb 15, 2010
Will not power on
First check the fuse in the plug, if thats good you will have to take the back off the tv, there are a few screws holding it on so have a route around and you will find them. Once the screws have been taken out the back cover should should come away, if you follow the mains cable into the tv and where the cable connects to the board there should be a small fuse, unpop it and take the fuse out, if you have or can get hold of a multimetre, test the fuse for continuity. You can also take it to your local electrical appliance shop and ask them for a new fuse, put the new fuse into the fuse holder and put the back into place and screw it back up, this should solve your problem. post back if you need further assistance.
2/4/2010 6:28:48 PM • Toshiba 32D46... • Answered on Feb 04, 2010
2answers
Tv turned on great, turned
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
12/7/2009 4:59:01 AM • Toshiba 32D46... • Answered on Dec 07, 2009
2answers
NOTHING BUT SNOW ON THE SCREEN
Are you connected to cable TV or an outdoor antenna? If on cable TV check the signal on another TV or if on an outdoor antenna you will need a digital TV adaptor to pick up local stations due to them not being available in analog anymore. Please take moment to rate my answer. Thanks...
11/26/2009 5:40:04 AM • Toshiba 32D46... • Answered on Nov 26, 2009
Horizontal line problem
The capacitor in horizontal section is popped and it needs replacement. Check the horizontal section capacitors and change the faulty capacitor.
Thanks.
11/21/2009 8:02:31 AM • Toshiba 32D46... • Answered on Nov 21, 2009
Toshiba 32D46 32" TV Logo
40 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
only two channels ant 3 ant 4
  • Televison & Video
