20 Most Recent
Innovage Jumbo Remote Control Questions & Answers
Have a jumbo remote with
I had the same problem Johny. Everybody wants to tell you how to program the one with the CODE SEARCH button. Here\'s how to do the one without. Press and hold the item button you wish to program (TV, DVD etc anyone of them can be used for anything) until the LED lights and stays on. Turn the item on manually and point the remote at it and push the power button. When the gadget turns itself off, immediately press the item button again. You can recall the code by pushing the item button until the light turns on again and then press DISP. Now push the number buttons (random is OK). As you hit the correct number of the code, the LED will flash until the four digit code is entered then the LED will go off. You may wish to try for more codes as some function better than others that just simply "work".
What button do I use for a cablebox
You have to setup the remote control to cablebox. If you wish to get more details about the setup proceedings to jumbo universal remote control,
check this link. Setup proceedings to some popular model remote controls, including jumbo remote control is given in detail. Pull up older posts there.
RCRP05B RCA Universal Remote
click "codes list" to download the pdf for the 4 and 5 device remote code list, this is asuming you have either the 4 or 5 device remote however.
I need a code for
Hello
Three digit remote codes for Zenith TV with Innovage Jumbo remote control are:
004 / 005 / 006 / 019 / 196 / 004 / 051 / 083 / 152 / 153 / 154 / 210 / 217
OK.
Sony blu ray player
Look for the codes at the Innovage web site. Not the problem? Be more specific.
Mother lost paper work for Innovage Jumbo Remote
Here are the codes,for the Tv,004,008,009,062,068,069,074,075,077,089,163,165,,if it is a combo,,062,115,001,...the dvd is ..173,183.....hope this was helpful...
Jumbo remote codes and steps
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button, for TV's not on the list.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
