Hi raj, i think problem is on cable you connect projector to get video signal form your Computer
Get a 10m HDMI cable along with setupbox which has HDMI out..
else switch to component video at least..if you want to do justice to the prj
Roughly on an average projector cost of watching 1hr of video comes to
around Rs 20-30.. don't waste that with poor quality cables.
Good luck ! if you think your problem solved don't forget to rate
When you monitor saying which is no signal this is a monitor port problem. Check your monitor connector if it is properly connceted to the motherboard. That is the only way of monitor saying no signal.
Most likely a cam sensor as this is where the fuel injectors get their information from. Check for a bad fuse with your linking error as you may not have a signal at the DLC.
I have a printer HP Laserjet 3050. this shows a problem "50 FUser Problem". Please turn off and start again. please give me detail solutions about this problem.
Firt remove the covering of the cabinet then locate a battery take it out rub it for few seconds.Place it back the way it was.Now if you have another cpu fan port on the mother board then plug your cpufans cable to it.Now restart your computer start pressing F2 ie bios settings.Now check the time and date. restart it again. See if it fixes the problem.
