You should not even try to install an operating system on an external drive. Windows looks at the "C" drive and installs programs to "C" drive. You are trying to put it on the "G" drive. You will have too many problems and wish you never had tried. Buy a larger main drive and partition it with two equal partitions. Then "Dual Boot". You will find how to do this on the internet. Just Google "Dual Booting".
SOURCE: Formatting the dv6226tx vista operated laptop to xp operating system
according to info its a Ricoh webcam
driver from hp is http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-38767-1&jumpid=reg_R1002_USEN
it might be it might not be i am not 100% sure
best thing to do is get the hardware ids of the devices in question find the chips used in pc and there shall be likely an xp driver on an older model i think dv1000t CTO some drivers might apply not all.
SOURCE: ACER 4720Z
It's very easy. You can switch SATA mode from AHCI to IDE (in Bios) and install XP, or leave AHCI mode, with 'nLite' integrate AHCI drivers into XP installatin files, burn and install... Drivers are not problem, just search in google, even ePower tools are working.
SOURCE: my external storage drive is
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
SOURCE: Formatting and Partioning WD My Book for Mac OS X
what are the tips of hard disk drive troubleshooting
SOURCE: I require a driver for our Beyond micro external hard drive.
I'm pretty sure that XP should pick up your external USB hard drive with relative aplomb unless:
1. The drive is USB 2.0 and your USB ports are 1.0 or 1.1 (and even then it should work, albeit at reduced performance)
or
2. Your drive is drawing too much power from the USB hub, causing an error condition.
Try plugging it into a different USB port.
Right click on you "Computer" Icon in your start menu
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
See if this helps you manage the external disk and get it formatted so you can use it on your laptop.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
