SOURCE: Karcher k4.98 switching on and off
The machine has a pressure leak. Check for a cracked controll head or either a leaking outlet elbow. The machine will short cycle if the holding pressure can not be maintained
SOURCE: the motor is pulsing on and off without the trigger being pressed
It is probably sucking air on one of the connections or around one of the fittings at the regulator. You can also turn the pressure up allittle on the regulator, that might stop it also. Make sure the clamps on the hoses going to the regulator is tite. Also it could be that the regulator is just bypassing water and if it has air in it it will pulsate.
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
SOURCE: I have a karcher 2400 psi pressure washer and it
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
SOURCE: karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
