20 Most Recent Karcher Hose Reel Questions & Answers
it is possible the rewinding spring broke .
Karcher Hose... | Answered on Feb 13, 2018
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Karcher Hose... | Answered on Feb 07, 2010
return it to Walmart
Karcher Hose... | Answered on Jun 23, 2009
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
Karcher Garden | Answered on May 15, 2019
This happened to my FC5 too. I found that the detergent outlet within the suction head was clogged up. This is the receptacle for the brass nozzle you can see when detaching the suction head (by pressing the grey button and gently pulling on the yellow "cover" at the top of the cleaning head - Figures 16.1 and 16.2 in the manual). To check it is indeed clogged, put a few drops of water in it - they won't drain out. To purge it I used the jet from a handheld steam cleaner, and I also used the steam jet to clean the suction slots. Be very careful not to scald yourself, wear gloves, and when cleaning just pulse the jet so as not to risk damaging the plastic parts.
Karcher Garden | Answered on May 03, 2019
Try this link:
https://www.youtube.com/watch?v=4WZgprLndhU
Karcher Garden | Answered on Mar 16, 2019
Maybe press regulator was reset before the unloaded was installed and needs to be set at lowest and then increased as needed.
Karcher Garden | Answered on Mar 06, 2019
Karcher Hose Reel Logo
Popular Tags
11 questions posted
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
karcher detergent draw problem
  • Garden
