Premier 24" Freestanding Electric Range - Biscuit Logo
Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the premier 24 inch stove with sealed burners. For whatever reason, the pilot light is not working, how can I reset it? Please note, the stove works when I use a match. Thanks
Anonymous
Level 3:
  • Master 552 Answers
  • Posted on Mar 08, 2011
Anonymous
Master
Level 3:
Answers
552
Questions
0
Helped
536836
Points
1583
More times than not the safety valve is the problem, you can read how to replace it and purchase the part by clicking on the link below,
http://www.appliancerepairlesson.com/
Atlanta Stove AIT3 model wall stove. will not light unless pilot light is held down...
Most pilot flames for gas burners are controlled by a safety valve. This model has a pilot safety valve. The safety valves function is simple, if the flame goes out for whatever reason the vale shuts the gas flow to the pilot light. The safety valve is controlled by a device that sits right next to the pilot (small cylindrec tube ( thermopile) that senses the pilot flame either by heat or dc current. To ignite the pilot light you have to manually hold down pilot light button until the the thermopile is hot enough (usually 5 to 20 secs), after that time, the thermopile will allow the safety valve to open. Check to see that the pilot's flame is making contact with the thermopile. If it is not, the pilot flame will require cleaning and or adjustment. If it is making contact, the you might need to replace the safety valve and the thermopile.
1helpful
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
5helpful
Premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Top Premier Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
