Hello, Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
There is a spark ignition plug near the burner. It could be dirty or the lead has come off. If you can hear the sound of the spark, that would mean that power is getting to the plug. If the problem continues you might consider buying a hand held gas igniter. Far cheaper than a service call.
There is a VERY complete tutorial on how to remove your oven door for hinge replacement or just for cleaning at https://www.youtube.com/watch?v=6YFTYWsiO1M
The narrator is clear spoken and the instructions are easy to follow not to mention the fact that you can go back to it any time for a refresher if you need to. Most ovens are very similar in how the doors work so this should do the trick.
then watch the next one for the cleaning directions
https://www.youtube.com/watch?v=GP2OC-NwxYU
I would add that you might want to wear rubber gloves. As a 5' woman I found that the oven door was a little heavy and the extra grip is handy. Be sure to have something ( like a small coffee table) to set the door on as soon as it's loose to prevent back strain.
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
Conflicting information in the link. My best guess is 2010 Month 11.The only way to be sure is to phone them.EDIT to Add./ I just noticed you typed 'Whirpool', I have edited your post but am not able to edit my link. When it opens, add the 'L' and press Enter.https://www.google.com/search?q=How+old+is+Whirpool+Gas+Range..
I am a retired career chef, and had this one oven with choking CO in an airport catering kitchen. We had it serviced and it was fixed. It sounds like yours is not getting enough air mixed with the gas. Adjusting the gas is one thing but the venturi to the burners can partially block and unburned gas spills over. Remove the burner and venturi and boil it out in whatever you boil your fryers out with.
Are you on mains gas or propane because the jets are different.
https://www.google.com/search?q=commercial+oven+emitting+too+much+Carbon+Monoxide
Here is text followed by a YouTube. Possible reasons why your oven won't turn on even though the gas and range hood are working:
Igniter: The igniter is responsible for lighting the gas in the oven. If it's faulty, the oven won't turn on. You can check if the igniter is working by looking for a glow when you turn on the oven. If there's no glow, it's likely that the igniter needs to be replaced.
Wires: The wires that connect the oven to the power source may have come loose or be damaged. Check the wires for any signs of damage or looseness and replace them if necessary.
Safety valve: The safety valve regulates the flow of gas to the oven. If it's faulty, the oven won't turn on. You'll need to hire a professional to repair or replace the safety valve.
Top 4 Reasons Oven Won't Turn On - Gas Range Troubleshooting (youtube.com)
