20 Most Recent Premier 24" Freestanding Electric Range - Biscuit Questions & Answers
More times than not the safety valve is the problem, you can read how to replace it and purchase the part by clicking on the link below,
http://www.appliancerepairlesson.com/
Premier 24"... | Answered on Mar 08, 2011
CONTROL BOARD PROBLEM NO DOUBT
Premier Kitchen... | Answered on Dec 28, 2018
CALL YOUR LOCAL REPAIR SHOP . IT MIGHT BE ADJUSTABLE THRU THE CONTROL KNOB . MANY WERE BACK IN THE GOOD DAYS
There is a spark ignition plug near the burner. It could be dirty or the lead has come off. If you can hear the sound of the spark, that would mean that power is getting to the plug. If the problem continues you might consider buying a hand held gas igniter. Far cheaper than a service call.
Premier Kitchen... | Answered on Nov 20, 2018
is that on HI or LO setting sounds like it's working the way it should for LO
Premier Kitchen... | Answered on Apr 16, 2015
check element contacts sometimes they work loose or corrode .
There is a VERY complete tutorial on how to remove your oven door for hinge replacement or just for cleaning at https://www.youtube.com/watch?v=6YFTYWsiO1M
The narrator is clear spoken and the instructions are easy to follow not to mention the fact that you can go back to it any time for a refresher if you need to. Most ovens are very similar in how the doors work so this should do the trick.
then watch the next one for the cleaning directions
https://www.youtube.com/watch?v=GP2OC-NwxYU
I would add that you might want to wear rubber gloves. As a 5' woman I found that the oven door was a little heavy and the extra grip is handy. Be sure to have something ( like a small coffee table) to set the door on as soon as it's loose to prevent back strain.
Premier Kitchen... | Answered on Mar 23, 2015
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
Premier Kitchen... | Answered on Feb 05, 2013
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Premier Kitchen... | Answered on Sep 30, 2010
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
Premier Kitchen... | Answered on Jul 10, 2010
sorry but you need to ask the propane provider .
Kitchen Ranges | Answered Yesterday
This code means on most ranges that the oven has got to hit. Try unplugging the range overnight. Tomorrow plug it back in. See if code has cleared. If if has great. However when you plug it back in and it shows a f2 you will need to call a service technician out to look at it. He or she should be able to give you a estimate for the new part. You my have a service charge if you decide not to get it fixed.
I hope this information helped. Have a blessed day!
Kitchen Ranges | Answered 2 days ago
There is a thermal fuse. It should be behind the back panel. The part number is WP4456654. I hope this helps.
Kitchen Ranges | Answered 3 days ago
Premier 24" Freestanding Electric Range - Biscuit Logo
7 questions posted
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
ray gallant
tmaree
tmaree
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Premier Kitchen Ranges
Most Popular Question
premier 24 electric range model
  • Kitchen Ranges
