It sounds like your carb needs to be taken apart and cleaned out. The gasoline in the carb sounds like it has varnished and blocked the passages in the carb. I would try some carb cleaner, if you are comfortable in taking apart the carb, you can use the spray cleaner to open the passages. You might have to soak the carb a bit as well.
