Error C000 has also been known to be caused by poorly seated or unseated ink tanks. Another method that can be used to try and fix Error C000 is to open the printer door and make sure that all of the printer's ink tanks are properly seated.
Jun 25, 2021
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or
foreign object that is preventing the Print Head Holder from moving.
For more informationabout theerrorcodeC000,canbe read hereCanonSupport andDownloads Youread,the bottom ofthe page
C000 indicates to remove the packing material. Remove packing material so that the print headholder can move.Confirm that the printeris powered off. Disconnect the power cord from the printer or at the wall outlet or both. Open the paper output tray and then lift up the scanning unit cover until it locks into position. CAUTION: The orange protective tape may prevent you from opening the paper output tray
After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already).1.Close the scanning unit cover.Reconnect the power cord and then power on the printer.
HiHi this code is. C000 indicates to remove the packing material. Remove packing material so that the print headholder can move.Confirm that the printeris powered off. Disconnect the power cord from the printer or at the wall outlet or both Open the paper output tray and then lift up the scanning unit cover until it locks into position. CAUTION: The orange protective tape may prevent you from opening the paper output tray
Pull the orange protective tape (A) in the direction of the arrow and remove the white plastic (protective material) (C). After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already).1.Close the scanning unit cover.Reconnect the power cord and then power on the printer.Found this code on the net hope it helps you.All The Best: Pineworks
