HP Pavilion zv6131us Notebook Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get the driver to use the Remote Control Infrared Receiver for an HP Pavilion zv6131us
Anonymous
Level 3:
  • Master 822 Answers
  • Posted on Feb 23, 2011
Anonymous
Master
Level 3:
Answers
822
Questions
Helped
240429
Points
2570
Download from their official website go this site www.hp.com
1helpful
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
9helpful
2answers
Hello, I am searching rc6 ir remote control drivers for hp pavilion dv7-1170us(win 7).... Please help me out to solve my problem
Hi, the drivers you are looking for your HP Pavillion DV7-1170 IR receiver are located here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
My infrared device is not detected
The infrared device on this laptop is only for HP remote controls or and Windows Media Center Remote. It is not for communication or data transfer. Its like the remote sensor on you TV. It will not show up in your Hardware Manager,
Hope that offers some insight.
I have an audio problem and a modem problem. Windows 7 does not seem to have drivers and hp has not made any either.
You can't get the drivers of windows 7,because the edition of windows 7 is only released for testing purpose, microsoft did not add any driver pack in windows 7
Lid is really loose
contact hp on http://www.hp.com and look up the service centre close to you.
HP dv8135 notebook Remote IR receiver doesn't install HID driver
It appeared you might need to down the newer version of the driver.
HP Media Center PCs - Troubleshooting the Remote Control and the IR Sensor
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=bph07914
2helpful
I think I have infrared, device manager says not there
*Smile* No, that is for your remote control that came with your PC. There should be a remote on the right side of your laptop. (Could be on the left.)
2answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
