20 Most Recent
HP Mobile Remote Control For Pavilion Dv4/Dv5/Dv7 Series PC Questions & Answers
My HDMI doesn't work, I plug in the cable and it
bet you they forgot to plug in the HDMI socket on the outside case of the laptop onto the motherboard of the laptop !
had experience of no sound on a tv that was repaired under warranty but could not fix it as I was not allowed under warranty to open the tv and plug in the sound cable to the mainboard. TV had to be sent back again for repair . and it ended up being the sound cable as I had pleaded with the manufacture to replug in without 6 weeks wait for the tv to be sent and repaired by a warranty repairer !
Hello, I am searching rc6
the drivers you are looking for your HP Pavillion DV7-1170 IR receiver are located here:
Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Remote controll driver for dv6000
You can try running windows update via the control panel in windows, or looking up the dv6000 on HP's site and look for product downloads. It should have a listing of all the available downloads for that particular laptop model.
My hp mobile remote control is not working
Hi okyerekdwent,
Try changing the battery in the remote. The battery might be dead. If it still doesn't work do a system restore to a date you remember the remote was working, as some applications might have disabled or removed the IR driver.
DV5-1138tx Remote not working
uninstall all the security software ..if any ..or
disable firewall
If u are using Norton Uninstall the software
this will make it work
also Note:-Vista has conflicts using the remote connecting any VPN network
Can not adjust volume
dere may bea problem wid d battery ,try replacing the battery ...if the laptop is in warranty den get d remote repaired ...
although u can repair it urself by opening d remote and rubbing d contacts wid some metal
