SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Hi
You can go to your program files on Drive C: when you explore your computer, look for the icon for scanner on Canon folder and right click on it, you can either copy and drag it on your desktop or right click and create a shortcut.
Hope this helps
SOURCE: Scanner does not showup in scanning programs
the scanner is absolutely working if connected
your problem is on the "ultra side bus"
it's not connected....
try to update your USB driver, maybe it's not support the old version
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
