To detect excessive wash tub movement and shut down the wash cycle. Here is a copy of my post from a real DIY forum; Google this Neptune TL Washer FAV6800AWW 5 post down. Here ya go.....in this post I discuss the issue related to unbalance error codes DC and UC; Your FAV6800A or FAV9800A is going off balance with DC or UC unbalance error codes during spin cycle and you see/hear the wash tub banging around at the start of Spin Cycle of the wash cycle or a Spin Only cycle. If this is the condition the TDS (Tub Displacement Sensor) is working as designed and signaling the Control Board properly of an unbalance wash load condition. If you need help open a post in that repair forum and I will try help you through your issue.
The Control Board receives a varying D.C . Voltage from the TDS sensor and if the out of range D.C. Voltage limit continues the Control Board will halt the Spin Cycle and try to redistribute the wash load. If you are interested I will show you how to monitor the TDS input to the Control Board with a DVM.
The Control Board then starts the Spin Cycle again. If the wash tub/basket out of balance condition continues the Control Board will attempt another redistribute of the wash load. After several attempts (4 to 5 I believe) the Control Board will shut down the Spin Cycle and send a error code DC or UC to the LED display of the FAV6800A, my machine type. And I believe a text statement to the LCD screen of the FAV9800A machine i.e. something like "Unbalance Condition" I'm not sure what the text message is.
The forum is free and my time is free I just don
SOURCE: Maytag Neptune FAV6800AW Code LL
Hey HopelessR,
The LL error code For the FAV6800AW is one of those errors that I feel is not documented very well. The only explanations I see is Large Load detected, “” The washer cannot spin because the load is to large”” OK what the heck is the trigger input to the Control Board to issue this error code to the Console Display????
I believe it’s Motor RPM not reached. I would try the Quick Spin Test on page 14 of the Service Manual and see if your machine will spin up to 850 RPM with an empty wash basket. Do you run up to 850 RPM “85.”?
I then reran the test with two large bath towels that were soaked, had to lay them in the wash basket to balance as best I could. I wanted to rerun the test with some load. The wash basket spun up thru all ranges to 850 RPM and completed with 3 beeps. Just wondering what RPM range you can complete too.
I have to additional commenst, this board has message limits for guys like me.
