SOURCE: Playback only on left speaker
It seems that the Samson driver has been reported to have some problems with stereo. Your choices are to use the mic in mono (which most recording is done in anyway) or unistall the SoftPre App which Samson provides with the mic and select a generic driver.
SOURCE: No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
SOURCE: why is my mic not picking up noise like it did when i first gotit
Double-check on the side of the microphone to make sure you didn't inadvertently activate the 10db pad. If so, switch it back to the center position.
Also, on the US-122, make sure that the input is set to "mic" and that you have switched the Phantom Power to the "On" position.
SOURCE: how to use Sony Electret Condenser Mic ECM-102
The closest manual I find is at http:// www.mutinymedia.co.uk/tie_clip_mic_files/ecm44b.pdf. Shows where the battery compartment is and gives specs and usage tips.
SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
