Kenmore 34721 Upright Vacuum Logo
Posted on Feb 10, 2011
Roller won't turn, - Kenmore 34721 Upright Vacuum
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Feb 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
5740
Points
97
Refer to your owner's manual on how to replace the belt. You have a broken belt if the vacuum is working fine but brush roll isn't turning. Either that or you have an option on your vacuum to turn the brush roll off???????
1helpful
2answers
The brushes and roller on my cordless shark ion f80 vacuum stopped spinning, Help
If you pull it apart make sure the roller and the belt is free of debris. And I would check the belt to see if it broken or real loose. If so contact Shark and see if they will send a replacement . (It may cost a few bucks) At least this is a first start hopefully it helps?
2answers
Bissell healthy home vacuum roller won't spin
Hi Helen. Your Healthy Home vacuum has a lifetime belt. If the belt needs replacing, you should bring it to one of our Authorized Service Centers for repair. Also, here is quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1394&cid=ccsocial
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
The brush on my kirby won't turn
It may have something caught in the roller mechanism if not the belt that drives the roller may have broken or slipped off. If the problem is neither of these then the motor that drives the belt to drive the roller may have failed, Please take to an authorized service centre and have it repaired or replaced if it does not cost more than a new vacuum if it is going to cost more than a new vacuum then discard that machine and purchase a new one. I hope this helps.
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
Jul 23, 2012 • Vacuums
2answers
Motor runs, brush won't turn, burning rubber smell
Easy to fix. The burning rubber smell is hair in the roller against the belt! Congrats, you have a healthy vacuum, you are lucky! Unplug the vacuum, remove the screws that cover the belt and roller brush. If you are nervous, take pictures with a cell phone or digital camera as you go for re-assembly. ok, pull the long roller out of it's slot and out of the vacuum. cut all hair off the roller and carefully move the belt from side to side to do the same. If the belt slips off, it slips back on easily. If the area is too tight for fingers guide it back on with any long thin wooden object. You can squeeze the belt to narrow it and slide it back over the thin metal rod that spins it from the motor. Slide the roller through the belt and back into it's slots. If it won't slide back on, turn it a quarter turn. Repeat till it does slide back into place. Put the face plate back on-tighten screws, flip it over, plug itr in and it should work!
Brush roller won.t turn. It turns for a sec. then shuts off. I have cleaned all clogs. This is a shark navigator. Can I remove bottom of vac to access the roller? The manual doesn,t mention this as a...
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
