It is possible that the other end of your power adaptor is defective or just loose. Tighten it securely and try to test if it is emitting voltages by using a multi-tester.
It can also be that there is a problem with the connection form your power adaptor going to the main board of your laptop.
This is a very technical problem so I suggest you let a laptop technician look at it.
Hope it helps.
Thanks!
