20 Most Recent Gateway FPD2275W LCD Monitor Questions & Answers
Gateway ZX4931 all-in-one will turn on (power
Power supply maybe but sounds like a motherboard issue. do you have a red light blinking on the front if so motherboard is your issue.
12/26/2023 5:20:06 PM • Gateway FPD2275W... • Answered on Dec 26, 2023
2answers
Acer p221w monitor removing base
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
8/23/2020 11:39:13 AM • Gateway FPD2275W... • Answered on Aug 23, 2020
2answers
HF289H Hannspree Monitor
While in the On Screen Display Menu the Icon second from the bottom contains settings for OSD timeout, you want to get to this function and set it to 20 seconds.
This is a link to the online PDF manual, go to page 18 for more detail on accessing and using this setting.
On page 19 is the information on resetting the factory reset functions. Do this, if you are struggling with the use of these buttons, read the manual for assistance. The manual is something you can read and reread and may help you immensly in getting to these controls.
On the last page of this online manual is the contact information for Hanspree and they have a toll free numberr. Wait until the weekend is over before calling. If anyone is working the phones on a holiday weekend they are low on the seniority list. You may or may not get good service on weekends.
Regards,
Worldvet
9/24/2019 5:59:32 PM • Gateway FPD2275W... • Answered on Sep 24, 2019
Gateway FPD2275W LCD Monitor - Powers up, backlight remains on, no Gateway logo on power-up....
The cable leading from the source to the the monitor has given up this is usually the problem and is the most likely culprit. OR The Input setting has changed there is generally a button that changes the source near the power button or a menu button that allows you to change source.
3/22/2019 4:27:44 PM • Gateway FPD2275W... • Answered on Mar 22, 2019
AOC color Monitor 7G1R
Where are your buttons located on your monitor? If you press menu there should be a reset option.
11/13/2018 1:53:15 PM • Gateway FPD2275W... • Answered on Nov 13, 2018
I have a Philips 170S4. On startup it displays the
did you adjust the brightness, also in windows settings? pls check with another monitor ,also you can check monitor with another pc or laptop try with reset the monitor settings also change the resolution and display frequency
10/3/2017 2:53:10 PM • Gateway FPD2275W... • Answered on Oct 03, 2017
10answers
Double Images / Shadows on the monitor screen
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
9/19/2016 6:23:16 AM • Gateway FPD2275W... • Answered on Sep 19, 2016
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
4/26/2016 3:01:05 AM • Gateway FPD2275W... • Answered on Apr 26, 2016
2answers
Gateway Monitor FPD1760
Power light coming on when you plug it in but no lighting of the screen is usually caused by the power inverter board having gone bad. Common on the 17s due to their age is a bad bulb or more.
I repair these 90% of the time
[email protected]
1/7/2016 12:55:09 AM • Gateway FPD2275W... • Answered on Jan 07, 2016
How do i unlock menu on screen?
Not difficult, but it's time consuming to goose chase a few things. You need to go the back on the monitor and read the electrical label. It will have UL (number) on it. Write it down. Go to the UL site and look up the UL number on the directory and it will tell you who made the monitor for Gateway. Go to the mfrs website and download a similar manual for the same size monitor as yours and read it, it will tell you exactly how to unlock the menu, if the Gateway manual didn't.
11/10/2015 9:59:11 PM • Gateway FPD2275W... • Answered on Nov 10, 2015
LG flatron wide 194 does not turn on
damaged capacitors
3/5/2015 6:31:06 AM • Gateway FPD2275W... • Answered on Mar 05, 2015
2answers
Nec lcd1560v+
http://www.necus.com/support/ go down to where it shows drivers and software, choose NEC MultiSync LCD ...
Download the NEC LCD monitor installer and run it, NEC shows your monitor supported by this software. :)
1/26/2015 7:22:33 AM • Gateway FPD2275W... • Answered on Jan 26, 2015
2answers
Laptop
First try reinstall the OS.
1/19/2015 6:41:38 AM • Gateway FPD2275W... • Answered on Jan 19, 2015
2answers
KDS K717s = Radius-73 Model 700P
Most are snapped at the corners and center of each side.  A plastic ipod pry tool will usually get the process started, and you just work your way around the frame.  Starting at one corner is best.
srich
1/3/2015 6:44:04 AM • Gateway FPD2275W... • Answered on Jan 03, 2015
6answers
How to disassemble 900w
The proview trims have to be slid upwards to remove them once the 4 screws are out of the bottom.
You'll need to lift the top part slighty away from the lcd to allow the sides to slide up.
If you don't slide it , then yes, you'll break tabs.
ebays bammbammfran
11/30/2014 10:00:50 AM • Gateway FPD2275W... • Answered on Nov 30, 2014
2answers
Desktop icon shadow in acer monitor as 1024*768 resolution
go into your graphics card config and change the brightness levels
11/6/2014 5:45:09 PM • Gateway FPD2275W... • Answered on Nov 06, 2014
7answers
LG Flatron L1932TQ won't turn on
I have the exact same problem. Just like Ptepe, I also found the 680uf/25v and 1000uf/16v capacitors in positions c203 and c204 on the Power Supply PCB to be bulging on the top. I considered replacing all of the electrolytic capacitors on the board, but decided to just try the visibly effected ones first. Please make note that the instructions provided below are to be followed at your own risk! Soldering on a delicate printed circuit board will be required for this repair and the board can be permanently damaged if done incorrectly, not to mention the potential for bodily harm! If you have warranty, you will obviously want to pursue that avenue first.
1) Remove the monitor's base by removing the plastic cover over the connectors and then the one over the base's bracket and unscrewing the four screws. While you're in the area, there are two screws, one on either side of the bracket, that must be removed. They are in the recessed wells.
2) Turn the monitor upside down so the narrow edge is facing you. You will see at either end of the bottom edge an arrow pointing toward a slot. Side a small flat head screwdriver under the cover in the direction of the arrow. With the screwdriver still inserted, unclip the bezel by pulling the plastic in the direction of the arrow. Repeat on the other side and carefully pry the rest of the clip points loose all the way around the screen, while carefully holding pressure against the screen so it doesn't fall out, and the plastic bezel will come off. Be sure to unscrew the switch assembly from the bottom. There are two screws.
3) Lay the monitor face-down on a soft, clean surface like a folded blanket. There will be five screws on the back with the fifth one in the center. Remove all of these screws and very gently lift the plastic cover away, making sure to keep the screen from falling out abruptly.
4) With the back of the screen and electronics exposed, you will see a sheet metal case with a few wires routing from it to three points on the monitor and the switch assembly. To the left you will see a metal cover held in by one small screw on the narrow edge. Remove this small screw and partially remove any tape that may be securing it. You may replace the tape later if it loses adhesion. Remove it, gently lifting the metal case where it overlaps the cover.
5) Next, partially remove any tape that is securing the wiring harnesses (it can be completely removed if you are planning to replace it). This will give the metal case a sufficient range of motion to allow you to lift it up on the right edge and expose the large harness routed to the top of the screen. This harness has a bit of tape covering the connector at which it terminates, and the tape must be lifted to expose the connector. Gently remove the connector straight out of the socket. Avoid diagonal movement as much as possible.
6) With the large connector removed, the metal case can now be flipped over, with the screen remaining flat, to expose the circuit boards it houses. On the left is the processor board, on the right (the one with the big capacitors) is the power supply board. First, remove the black plastic cover over the power supply board. This may require some flexing of the plastic and/or clips. Be sure to make sure any wires attached to it are detached. Next remove the small metal slide panels covering the upper and lower wiring harness connectors on the case (the ones routed to the upper and lower parts of the monitor on the left side). With the two upper and two lower connectors exposed, note their positions and disconnect them.
7) Now the case is completely disconnected from the monitor. Carefully remove the connector from the board on the right that connects to the board on the left. Unscrew the four bolts holding in the power supply board (the lower left screw is larger than the others). Carefully lift the board out, angling the side with the power connector downward. Be very careful not to touch components on the circuit board.
8) By comparison, you may clearly see which capacitors are bulging on the top. These are the ones you want to replace. If mine and Ptepe's experiences are consistent with yours, you will see two out of a cluster of six larger capacitors with bulging tops (the cluster is on the opposite side of the really big capacitor and the two common capacitors are surrounded by the others). While you have the board out anyway, check for continuity through the fuse with a Digital Multimeter and check for any visible defects such as burn marks or melted solder points.
9) Very carefully desolder the effected capacitors. Verify their rating (most likely one 680uf/25v and one 1000uf/16v capacitor) and order them. If you'd like to replace all of the medium capacitors, it couldn't hurt. You can even replace the really big one if you want, but make sure you measure everything...including height, width and terminal spacing. For the ones that I used, though, they're 10mm x 20mm radial aluminum electrolytic capacitors with 5mm terminal spacing and 105C temperature rating.
10) Solder in the new capacitors, clip the excess pin lengths and reassemble in reverse order. It may take some finesse to put everything back the way you found it, but if you paid attention while you were taking it apart, it shouldn't be too hard (and taking pictures with your camera phone along the way can help too).
This solution worked for me. If it wasn't for shipping, I would have paid $1.18 for the entire repair. If you can find it, the power board can be replaced as an assembly, too, if you screw it up. :) Good luck!
10/4/2014 3:05:23 PM • Gateway FPD2275W... • Answered on Oct 04, 2014
How do I change the language
There should be buttons on the monitor itself that allow for that, as well has for changing the contrast, vertical, horizontal, etc.
9/20/2014 8:20:45 PM • Gateway FPD2275W... • Answered on Sep 20, 2014
Gateway FPD2275W LCD Monitor Logo
726 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
lg flatron l1932tq turn
  • Computers & Internet
