20 Most Recent
Dell Latitude CPI-D Notebook Questions & Answers
My Dell CPi D266XT will not power up. The light on
It is possible that the other end of your power adaptor is defective or just loose. Tighten it securely and try to test if it is emitting voltages by using a multi-tester.
It can also be that there is a problem with the connection form your power adaptor going to the main board of your laptop.
This is a very technical problem so I suggest you let a laptop technician look at it.
Hope it helps.
Thanks!
Have Dell D266x gives me dell page that says bios
Visit the Dell Drivers Downloads websites and download the lastest BIOS version for the notebook.
See if you can get an MS-DOS version. Boot the system using an MS-DOS repair disk. then attach the disk with the BIOS setup by USB.
If you don't see an MS-DOS version, you may have to format and install or do a fresh install of your operating system (or a lower version that supported the BIOS). As soon as windows is re-installed, run the windows version you downloaded from the source disk you saved it.
This should work!
I have forgotten admin password of bios .i need to
YOu can reset bios password with 2 method.
(1) open back cover of
laptop then find motherbord .Pull cmos cell from motherbord for 15
minutes then again put it in it's position .then it not ask for
password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Just tried to install xubuntu using cdrom to dell
Glad the ac adapter only being hooked up worked. Keep in mind that when batteries get to low that they can actually short out a laptop. Just some good info to know for the future. Hey if you can rate me on my solution to you I would be much obliged and I hope you get ubuntu working properly. I still want to get it to work on my other laptop, seems like a cool operating system.
Hard Drive not found
try checking this issue using some other HD if the other one works fine then get this one replaced..
Left & right arrow keys not working.
Try to connect an external keyboard, see if that one works. If it does, then the problem is most likely a loose ribbon cable from the internal keyboard to the motherboard (especially if you recently installed a new one) - also, while you are examining the cable, look for any tears, cuts, or kinks in the cable. Good luck!
How do I factory restore a dell latitude cpi d266xt
first of reset bios to default.
you can can use any xp disk as long as you have cd key(any valid cd key for that matter)and install fresh copy (factory set/default)
eg I have 4 laptops and a tower pc all of which I have xp pro installed from same disk and same key +sp3 and ie8 and nav360
Will not power up
please check with the power cord and see whether you see a ligh on the machine if yes then try to power on in the safe mode if it opens up then check some of the hardwares connected to teh machine and then try to disconnect them
that will work if still doesnot work on the ac adapter also then mobo ( motherboard) needs a replacement
How to fix my dell E4310 from freezing while im using it?
There are a number of reasons that the unit could be freezing up.
- Corrupted file(s)
- Low available disk space
- Viruses and/or malware
- Too many add-ons/toolbars/etc.
- Heat build-up
Number one is the hardest to find. So start with #2. The computer needs free hard drive space to operate. If the disk is nearly full or is very fragmented, this can slow the machine to a crawl. Check for available space and if there is plenty (20GB or more), then check for fragmentation under administrative tools. If the defragmentation tool recommends optimization, allow it to perform it and see if that helps.
For viruses and possible malware, run your virus scanner. It is always a good idea to get a second opinion on such things. Malwarebytes is a free malware scanner that works very well to find adware and some things that many antivirus programs fail to detect.
Many user feel that they have to have every bell and whistle. I've seen some browsers with 7-10 different toolbar add-ons. These almost always come with some adware and always slow down the browser. Uninstall all but the most essential toolbars for the best performance. Heat is a slayer of machines. Laptops are very susceptible to heat issue since they are often placed on beds, sofas, carpets, and yes, even laptop. Many of these units draw cooling air from the bottom and exhaust it to the side. Even those that draw air from the rear and exhaust to the side will often intake large amounts of dust, grit, and lint. These can partially or completely clog the heat sink unit and cause heat buildup of the processor. This will cause the processor to work slower and can actually cause it to thermally lockup, resulting in the need to reboot. Many units can be accessed to clean with a removable cover on the bottom; others may need to be serviced by a technician to clean.
My latitude will not power up. I have a good power
no PC told , at all, model not told
ok generic mode.
1: huge battery inside is bad, shorted remove it , even for ever.
2: run on AC power only now.
3: push power button 10 full seconds release, ,runs now?
4: no, remove all USB devices now. run now?
5: no, coin cell battery dead, , replace it , run nolw
6: no. strip the PC down to find the shorted model.
lap-strip-101
https://www.pcdied.com/Dead_screens/dead-LT.html
Can you hard wire power to laptop?
NO
if you do, a noob will blow it to kingdom come. as in letting the smoke out.
the power-pack does 3 things
it has the correct DC voltage and wattages
and #2 prevents fire when the PC fails and things short inside.
and prevents huge damaging surges landing inside the PC
buy used power pack off fleabay and win.
i bet I'd mow one lawn and and buy one
