Expert
- Posted on Feb 04, 2011
Re: Microwave runs lights come on but it doesnt heat up...
It shows that magnetron is not operating,check high voltage diode grounded from the high voltage capacitor by replacing the same with same specification,if problem remains then check connection leads connected with magnetron for loose or corrosion,finally check by replacing the magnetron.
This type of problem occurs due to many reason ,most common are HT transformer supply missing,HT diode which is reverse grounded with capacitor may be faulty check by replacement or finally megnatron ,(this device is responsible to generate micro waves)may be faulty chek the same by replacement
