20 Most Recent
DeLonghi MW 605 Convection/Microwave Oven Questions & Answers
Where can I get user manual for Delonghi Touch
You can download the complete instruction manual in PDF format by clicking this
link.
On the page which opens, click on the "
Download" button to download and save the manual.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
Microwave is slow to heat
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Easytronic deloghi microwave, all electrical
Please check the start button if its functional. The timer must be counting once you press the start button. Check also the air filter if it has dirt and dusts . Some ovens are equipped with sensors that disabled the unit once the air filter becomes dirty.
My father had an accident last week with his
If it is still under warrenty, do not have anyone touch it as it will then be nul and void. There will be 2 problem now with the microwave. The initial bang is one and the door comming off is the second. Making a long story short, replacing the microwave would be the best bet as the spares and labour and down time will not be viable. So try for that warrenty.
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit... Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/lisa_52daba487e5b4d53
Does not turn on power suppy is ok
Hello there:
If you have already checked the fuse that is inside of the microwave and it appears or is known to be good than the circuit board that the fuse sits on is faulty or the sensor for the touch pad is bad
there are several capacitors that controle different features of this microwave and unfortunatly when one of these small capacitors blows it affects the whole board
the good news is that the board is replaceable normally around $50-75 dollars ok
hope that this is very helpfull for you
best regards michael
