20 Most Recent Sharp Carousel R530EST Microwave Oven Questions & Answers
Need to know the heat number system - is #1 the highest heat setting or the lowest heat setting?
According to the information provided in this article on Lifehacker, 1 would be the lowest power setting. Source: http://lifehacker.com/5974788/familiarize-yourself-with-your-microwaves-power-settings-to-make-microwave-cooking-a-joy
5/8/2019 12:32:16 PM • Sharp Carousel... • Answered on May 08, 2019
Microwave runs lights come on but it doesnt heat
It shows that magnetron is not operating,check high voltage diode grounded from the high voltage capacitor by replacing the same with same specification,if problem remains then check connection leads connected with magnetron for loose or corrosion,finally check by replacing the magnetron.
3/4/2019 8:25:49 AM • Sharp Carousel... • Answered on Mar 04, 2019
How do I set the power level
Enter the cooking time. Press the Power Level button until the desired level is displayed - Level 1 = 100%, Level 2 = 90%, ... Level 10 = 10%.). Press Start button.
1/17/2017 7:37:06 PM • Sharp Carousel... • Answered on Jan 17, 2017
I cannot reset clock
Touch Timer/Clock pad and number 2 pad. Enter the correct time of day by touching the numbers in sequence. Touch Timer/Clock pad again.
9/3/2016 2:18:25 AM • Sharp Carousel... • Answered on Sep 03, 2016
0answers
0answers
How do i remove the display on a sharp carousel microwave in order to get roaches out?
Take of the main cover and turn upside down and give it a good shake to clean out.
1/9/2015 1:51:28 AM • Sharp Carousel... • Answered on Jan 09, 2015
I cannot find a user manual for Sharp R530EK-T
Google "Sharp R530EKT user manual" several will show up.
12/8/2014 9:30:45 PM • Sharp Carousel... • Answered on Dec 08, 2014
Sharp carousel microwave
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
8/25/2014 10:47:47 PM • Sharp Carousel... • Answered on Aug 25, 2014
How many watts has my R-9H83 Sharp micro/conv.?
No idea, but the label on the unit should tell you.
8/15/2014 2:31:24 AM • Sharp Carousel... • Answered on Aug 15, 2014
Door will not open on sharp microwave r-530es
The door latch is either loose or broken.
7/30/2014 6:05:40 PM • Sharp Carousel... • Answered on Jul 30, 2014
0answers
0answers
Why numerical buttons doesn't work and microwave
fuse?
9/28/2013 2:43:00 PM • Sharp Carousel... • Answered on Sep 28, 2013
Sharp Carousel R530EST Microwave Oven Logo
88 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
remove display sharp carousel microwave
  • Microwave Ovens
