20 Most Recent Sharp R-1480 Microwave Oven Questions & Answers
4answers
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
4/10/2023 7:58:06 PM • Sharp R-1480... • Answered on Apr 10, 2023
Turning off repeated beep when
Hi, Pull the plug for 10 minutes and try again. Good luck.
5/9/2021 11:01:39 PM • Sharp R-1480... • Answered on May 09, 2021
2answers
Door opening internal plastic hinge broken
Just saw you post as I was searching for the same item. If you have not found the part yet, it can be ordered from repairclinic.com (part #916507). $5.50 plus shipping.
2/24/2021 7:26:56 PM • Sharp R-1480... • Answered on Feb 24, 2021
10answers
Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
7/1/2019 6:43:53 PM • Sharp R-1480... • Answered on Jul 01, 2019
Can I use rustoleum paint inside my microwave?
Microwave radiation is non ionizing, it is impossible for to cause the kind of mutations that cause cancer
10/18/2018 6:01:49 PM • Sharp R-1480... • Answered on Oct 18, 2018
I have a microven Sylvania,
No use on fixing the oven. They cost $150-300 so why bother?
2/9/2018 11:49:03 PM • Sharp R-1480... • Answered on Feb 09, 2018
Boiling water caused large "Pop" sound/microwave not working now
I would guess that the boiling water may not have been the cause ... If you are lucky ... try this first: Unplug or turn the circuit breaker off (if it is a built in unit). Wait an hour and then repower. Odds are that will not clear things up ... but it is easy to try. Probably one of the electronic internals broke. A number of different internal component problems could cause this heating failure in the microwave. It could be the magnetron, the high voltage transformer, the PC board, the diode, and the capacitor. This type of problem will need to be diagnosed and repaired by a service technician. Microwaves are inherently dangerous to service. This type of repair is not something that you want to try to do yourself. Internal capacitors in the microwave can retain a lethal electrical charge even when the microwave is completely unplugged. A microwave radiation leakage test should be performed on the unit using proper testing equipment following any internal component repair.
1/25/2018 7:53:45 PM • Sharp R-1480... • Answered on Jan 25, 2018
I have sharp microwave oven
First I would suggest a "hard reset". Simply unplug the oven for a minute or two, then try again.
If it still fails, it may be that the keypad has failed, or there is a bad connection due to moisture, grease, etc.
This is an Australian model, so it's hard for me to give more specific information.
But one some US models the LCD and keypad connect to the circuit board via a rubber "zebra strip" and losing that connection can result in a loss of display segments and / or key response.
I've attached a diagram showing where one can clean to restore operation in this case.
12/6/2017 3:25:30 PM • Sharp R-1480... • Answered on Dec 06, 2017
Sharp carousel II R-1A54 control panel issue
Check or replace your door switch.
10/29/2017 6:25:49 PM • Sharp R-1480... • Answered on Oct 29, 2017
I cannot get the clock-setting
To set the clock to 4:30, for example:
CLOCK > 4 > 3 > 0 > CLOCK
- or -
CLOCK > 2 > 4 > 3 > 0 > CLOCK
(the two means you're setting the clock, as opposed to 1, which would be to set the timer)
8/21/2015 9:56:50 AM • Sharp R-1480... • Answered on Aug 21, 2015
Dimensions of sharp r-1480 microwave?
Per http://www.homeportfolio.com/catalog/Product.jhtml?prodId=5258 29 15/16" W x 16 3/8" D x 15 1/4" H
12/20/2014 2:39:40 PM • Sharp R-1480... • Answered on Dec 20, 2014
2answers
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch Custom Help, the number 1 and Start/ Touch On. Should a pad be touched, LOCK . .. ON will appear in the display. To cancel, touch Custom Help and Stop/Clear. " Also, to find manuals........
10/6/2014 4:55:20 AM • Sharp R-1480... • Answered on Oct 06, 2014
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
9/24/2014 2:12:08 AM • Sharp R-1480... • Answered on Sep 24, 2014
2answers
I put a metal pan
Yes it is safe to continue using the Microwave as long as the integrity of the glass is not compromised and the pitted marks do not exceed 1/4 inch. The RFwave generated by the magnetron is a pretty wide RF wave beam.
If your really concerned you can take the unit to any appliance service center and ask that they perform an RF leakage test. There is really no other way to know if your leakage is within acceptable limits. I can tell you from personal experience that the ony microwave I ever saw demonstrated excessive leakage had either been dropped and had hinge or latch damage.
If your really worried about it and can not get to a service center you can do this test:
- Wrap a tall empty glass with a sheet of aluminum foil and place it about 3 inches away from the microwave in front of the area you where noticed the pitting.
- Run the microwave with a GLASS filled with water of equal size for 1 minute.
- Stand back 3 to 4 feet and watch for any signs of a spark on the aluminum foil.
- As soon as the microwave shuts off check the dry foil wrapped glass for any signs of heat.
(No heat.... no problem. Sparks or Heat = repair time.)
Thanks for choosing FixYa.
Kelly
9/20/2014 3:20:26 PM • Sharp R-1480... • Answered on Sep 20, 2014
0answers
Sharp R-1480 Microwave Oven Logo
368 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
sharp carousel microwave door latch
  • Microwave Ovens
