A common problem is the battery tab on the circuit board. We repair this by reheating the solder joint on the circuit board where the battery tab is attached.
Sometimes
all it takes is a restart for the iPhone to become responsive again. To
restart your iPhone when it is unresponsive, press and hold the
sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It
is possible for an iPhone to become unresponsive if the battery drops
to an extremely low level. Plug the iPhone into your computer or wall
charger and allow it to charge for at least 20 minutes before using it
again.
not many engines have a low oil sensor so it is up to the driver to keep an eye on the oil light or check the level at least every other day
if you get a socket onto the harmonic balancer nut and try to turn it , that will indicate if the motor has seized or not
clicking starter solenoids indicate loose battery terminals , dirty terminals bad ground wire connections bad battery ( load test will check that)
Yes, no alarm , no countdown, for sure it s the battery,look on the small second hand wich advances 4 steps every 4 seconds. i have the same problem we hae to change the battery
hi..This problem is due to the low battery.orange
light indicates that battery is low.you need to
change your battery.
check it out..
thank u..
kindly rate my response..
i had the same problem with my dash saying battery voltage low and the problem was my alternator. took it to the dealership and it cost me $400.00 to replace a connector on the alternator because for my year car a (2002) they don't replace entire alternator.
I take no responsibility if you damage your tt in this procedure.
To open the tt one third edition and change the battery you will need a # 8 and a # 6 torx bit. Remove the 4 # 8 torx screws on the back of your tt. After removing the screws carefully insert a guitar pic between the two halves starting at the top and continue around to the sides. Be careful so you don't damage the case. After you have gotten the three sides loose (top, right side, and left side gently pull the two halves apart from the top (be very careful at this point so you don't dislodge the USB port). Do NOT take it completely apart at this point because you have to remove the battery and speaker connections (they just pull out with a little wiggling motion). After you have taken the case apart and disconnected the battery and speaker cables you will need a # 6 torx to remove the board (don't skip this step because the battery is held in with two sided tape and you have to pry the battery out). Now that the board has been removed take a small screwdriver and pry up on the battery. Now all you have to do is reassemble your tt in the reverse order. Just remember the smaller screws are for the board
