Hi johnny_johnm
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
If your flash drive data is still getting corrupted
After going to My Computer, Right click the Removable drive, Go to Properties >Tools. Run Error Checking and Scan for errors
and fix them. The files that are corrupt or in bad sectors already will
not work but at least the new transferred files should work.
If all fails, format your drive.
It will delete all the data from your USB drive and
make it fresh and hopefully remove all errors. The software for
formatting comes on the CD or available on support sites for your
branded usb drive on the net. For some reason, when I ran this
formatting software, it would say the USB drive is not connected.
How did I format my flash drive?
Right click removable drive and select and format the drive. Then scan and fixes all errors. So all the bad sectors are fixed and my drive has become all new and is working well now.
In the File System drop down, you will see FAT and FAT32. So which one to select?
If you right click Removable Drive >Properties
What happend to [email protected] ?acct was suspended
I had same probs and had to replace it. below is the option i tried but it didn't work for me.
Registry
Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. If uncomfortable with using Registry Editor, see if you can find someone who is comfortable and that you can Trust. Use Registry Editor at your own risk.
For XP Machines Only
Quoting :
1) Click Start->Run.
2)Type regedit and hit enter.
4)Click on the plus sign next to HKEY_LOCAL_MACHINE
5)Click on the plus sign next to SYSTEM
6)Click on the plus sign next to CurrentControlSet
7)Click on the plus sign next to Control
8)Click on the plus sign next to StorageDevicePolicies
9)Write click on WriteProtect and click modify.
10)If the value data is 1 change it 0 and click ok.
11)Repeat steps 7 to 10 for ControlSet001 and ControlSet002 .
12)Close Registry editor and restart the computer.
If you don't find it in the registry, the best way is to create it yourself. Below is the procedure.
Start the Registry Editor
Go to the HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control key
If there is no key called StorageDevicePolicies, create it
You do this by right-clicking the HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control key, and selecting New > Key from the menu.
Select the StorageDevicePolicies key
From the menu select Edit > New > DWORD Value
Name the new value WriteProtect
Right-click the WriteProtect value and choose Modify
In the Value Data: box enter 1
Exit the registry editor, and restart your computer
SOURCE: i cannot open my pen drive. 'A corrupted and
By the sound of it, this memory stick has become corrupted in some way. Have you take it out of a computer without safely ejecting it, by any chance?
It's unlikely that you'll be able to get your data off it now, unfortunately. Your best bet is to reformat it. On a Mac, use Disk utility - select the memory stick and go to the 'Erase' tab. On MS Windows, find it in your file browser, right click and select 'Format'.
Hope this helped!
