Try the link below for an explanation of beep codes.
https://www.pcmag.com/encyclopedia/term/38515/beep-codes
SOURCE: ram questions
Get 2 X 512 modules as this is maximum that is supported by each slot. (you have 4 slots on your VAIO).
At the moment you have :Standard Memory: 512MB removable
Here are the memory specifications:
You can get one for rather resaonable price from crucial.com
http://www.crucial.com/store/listparts.aspx?model=VAIO%20VGC-RB53%20Series
SOURCE: Sony pcv-rz22g startup long beeps nothing on screen
Long beeps appears that VGA card are not connected properly. check on it. if not tells us how many beeps you hear...
SOURCE: My Sony VGC-RA826G Desktop turns on and then beeps
Sounds like a memory error. Try pulling out one stick at a time until it is able to boot. Assuming, of course, you have more than one stick. If not, buy or borrow a new stick and try that. With 3 beeps the bad stick is likely to be in DIMM slot 1.
here is a description of beep codes for various BIOSes:
http://pulonangka.web.id/software/beep-codes-error-codes
SOURCE: When I power up computer, I get 2 very rapid beeps, pause, 6 beep
it depends on the beeping
but i guess it's ur graphic card
make sure that the card is firmly in place and also check the memory modules.
