It needs to be shimed,either floor uneven or casting is not uniform.It is a problum most people don't understand.Toilets when set need to be leveled if not you can break bowl.Go to home depot and in plumbing dept. ask for plastic shims-come in little bag,tap under toilet and then snug down bolts,(don't reef on bolts)when shes tight take flat head screwdriver and hammer and chop off shim flush.You should take dap tub and tile caulk (water soulible) and dap around bottom-keep wiping sponge with clean water around till it looks nice let set up for 12-24 hours,toilet should be rock solid.If by chance its leaking around base you'll have to reset with new wax Richie
This is not an easy one as it could be a lot of different thing causing this problem. The easiest one first, check to see if the bolts holding the toilet to the closet collar are tight they may be under the two half round covers on either side of the toilet bowl. If they are not tight you can try tightening them be real careful not to break the bowl flanges. If that doesn't fix the problem you will need to take up the toilet and see if the toilet flange is in good shape and that the floor has not rotted out or that the bolts have not pulled loose from the closet flange.
As you can see this could get into a lot of work.
Good Luck.
