Computers & Internet Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Santa with his son Banta were traveling on a boat after traveling one mile from the starting point the hat of Santa fell down. After 5 minutes Banta told his father about the hat. Santa turned the boat and after another 5 minutes caught the hat at the starting point. Find the speed of the water stream?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jan 27, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557698
Points
31058
At time 'ZERO', the hat was at distance 'ZERO' from the starting-point.
At time 'T', the hat was at distance 'ONE MILE' from the starting point.
The speed of the boat was the MAXIMUM speed of the boat, MINUS the speed of the current.
At time 'T+5', the hat was being carried by the stream-current toward distance 'ZERO'.
At time 'T+10', the hat was at distance 'ZERO', and the boat was at distance 'ZERO'.
The speed of the boat for the most-recent '10' minutes was the MAXIMUM speed, PLUS the speed of the current.
So, calculate the distance travelled at the 'T+5' time:
DISTANCE = VELOCITY1 multiplied by TIME1.
DISTANCE = VELOCITY2 multiplied by TIME2.
where 'VELOCITY1' is the speed travelling AGAINST the current,
and 'VELOCITY2' is the speed travelling WITH the current.
Finish this "homework" assignment on your own.
So I got this H.W question, can you see if you can put it into an equation, and solve it? How fast is each boat traveling in knots? The tall ships speed multiplied by 10 hours equals the distan
First translate the various statements of the problem into equations. then try to solve the equations. It won't do much good if I just gave you the answers.
My car is overheating after driving 2 miles
It could be any of those things but you be lucky and just need a coolant hose replaced.
Halfway point between 2 cities
It is Paso Robles on 101 at the intersection highway 101and 49,you can also travel interstate 5. hope this helps.
4helpful
3answers
My new Coleman SCANOE sank.
Look up the "Bird Of Prey Canoe Stabilizer" on YouTube. For less than $80 a guy made stabilizers for this model of canoe. I'm looking into buying one and found your post. I have read in another area that people were having issues with it taking on water in the back while using a motor. We mostlly row, so at most I was considering a small trolling motor.
Train A and B are traveling in the same direction on parallel tracks. Train A is traveling at 100 miles per hour and Train B is traveling at 110 miles per hour. Train A passes a station at 9:25am If train...
The first thing to figure out is the amount of time between the trains is 12 minutes. That would mean for train B to pass the station at 9:37 it would have to travel 22 miles in 12 minutes. Because, traveling at 110 miles/hour in 12 minutes the train would have travel 22 miles. Shown below shows the interpolation to come up with 22 miles.
Train A had to traveled 12 minutes so, it would have been 20 miles ahead of the station. Screened below shows the interpolation to equal 20 miles.
Though this calculation of 20 miles isn't necessary for the parametric solution that is being shown. It was very helpful in my solution in successive approximation. This parametric solution's starting point is at 9:37, not 20 miles ahead.
Using successive approximation, when train A traveled 200 miles in 2 hours, and train B was only 2 miles behind train A. At that point the time varibles needed to be broke down to minutes and seconds which gave me a real accurrate answer. Both trains were side by side in 2 hours and 12 minutes, and had traveled 220 miles from the station. You wouldn't believe how far the significant bits needed to be carried out to get such an accurate number. That's what gave me the idea to substitute, and use a parametric solution. In this solution the t (aka. time) is going to be substituted for the y axis. Next, I broke miles/hour down to mile/minute because, I knew the answer was in minutes: 2 hours and 12 minutes.
110/60=1.833333 so, -20+1.833333 t and 100/60=1.6666667 so, 1.6666667 t
Now load the equation:
Now let's look at the solution from the graph. Each line represents a train.
Notice how the two lines are converging. Where the two lines meet is the exact point when the two trains are side by side.
Substituting t (aka. time) for the y axis show that at the point when the trains were side by side equals 132 minutes. Or 2 hours and 12 minutes. The distance traveled x axis=220 mile from the station.
To a point successive approximation would have been messy, and hard to follow. Somethings can only be solved by using graphs, or better solved by using graphs.
2answers
Car is trying to start but wont turn over. spark
Have the fuel pressure checked. Fuel pump may have given up.
Laptop fell and wont boot up properly
remove battery, remove power. wait 5 minutes
start up
get back to us plz
4helpful
2answers
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
While running at highway speeds my 94 sportster lost power
Sounds like a bad coil, you should be able to have it checked at a bike shop.
Grand Canyon Tech
Grand Canyon Tech
