Sewing Machines Logo
Posted on Jan 26, 2011
I've forgotten how to drop the feed dogs-can you help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
404
Points
There is a little lever on the back of the free arm at the bottom. Push the lever to the right and that will lower the feed dog.
Anonymous
Level 1:
  • Posted on Jun 28, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
404
Points
My Janome Memory Craft 3000 suddenly started skipping stitches. After cleaning out the lint as well as I could, the machine won't pull the bobbin thread up. Any ideas?
3 Related Answers
Anonymous
  • Posted on Apr 24, 2009
SOURCE: janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Anonymous
  • 13 Answers
  • Posted on Aug 28, 2009
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Anonymous
  • Posted on Dec 26, 2009
SOURCE: I have a janome 1600p. how do i drop the feed dog
there is a little metal plate that fits over the feed dogs, this is what I am using
Machine 940 lights up feed dogs are up, but the stitch lights don't and it wont run
fees problem
https://www.youtube.com/watch?v=7fWwCCAHTxk
: The feed dogs are down and will not help guide the fabric.
  1. Raise the presser foot lever, and then slide the drop feed lever.
  2. Set the lever in the. position for normal sewing.
  3. The feed dogs can not be raised only by sliding the drop feed lever to . Raise the feed dogs as described below. Slide the drop feed lever to .
https://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=hf_pq1500seuk&faqid=faqh00000058_000
Says lower feed dog. It is lowered
The drop feed plate could be damaged of bent near the hook race. Then the feed dog could be binding and not dropping all the way down. Replace the plate. There is a micro-switch that reports the feed dog status. This switch may not be activating correctly when the feed dog lever is moved up and down. The switch will need to be checked for damaged wires/connectors and replaced if faulty. This should be done by a good sewing machine repair person.
I hope this helps. Please add a comment with the make and model of the sewing machine for information on the correct drop feed plate.
2answers
Where is the drop feed dog on this machine
Grace, it would be extremely helpful if you posted the manufacturer and model of you machine, so that we can help you. Your machine may not have a drop feed lever; on some machines, there is a cover placed over the feed dogs instead.
2answers
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
9helpful
2answers
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
How do I get the teeth to grab and advance the material on my very old Bernina 830?
Well there's a number of reasons why it may not be advancing the material. First, ensure that the teeth are completely cleaned-out - get an old toothbrush, or similar with firm filaments and, with the stitch-plate removed and the bobbin door open, give the teeth a really firm clean across the teeth to remove anything in between ... this is especially important if you've been sewing with metallised fabric or thread. If the teeth are nice and clean, check if they are still pyramidal with a reasonably 'sharp' point facing backwards - if the machine is very old and very well used, the teeth might be rather rounded and it may be time that you have a new feed dog fitted ... some of the old machines are difficult to obtain spares, but they're mostly still out there. Most commonly, check how far the teeth of the feed dogs protrude above the stitch plate ... this is a bit difficult to do and should really be done with a proper gauge, but generally they should protrude 1mm above the stitch plate - less than that and you wont get the material to move properly, especially if its fine material. Lastly, it could be the foot pressure that's the problem ... if there's inadequate foot pressure, the material will not be pushed adequately onto the dogs. Again, unfortunately, you really need a proper gauge to set the foot pressure, but if the dogs are clean, in reasonable condition and have 1mm of clearance above the stitch plate, you can try increasing the foot pressure a bit. This is done by opening the top cover and you will see a large-ish flat-blade screw in a threaded tube just behind where the needle bar goes up and down and to the left of the takeup arm. If the screw is rather near the top of the threaded tube, you can try screwing it down (clockwise) maybe 2-3 turns to see if it makes a difference ... of not, dont be tempted to just keep screwing up the pressure ... there's something else wrong. Oh .... and by the way .... before you've done any of the above, I assume you've checked that the feed-dogs are not dropped ! You can drop the feed-dogs to do embroidery etc on the 830 - there's a small round knob below the stitch length control - make sure its turned to the position that shows a tooth pattern and not the cross-hathced pattern and make sure the feed dogs do actually come above the stitch plate when turning the handwheel - if they dont, or moving the feed-dog drop control doesn't make any difference, then the link mechanism is almost certainly jammed (really, really common on old machines that haven't been regularly maintained!). To free that off, you need to remove the free-arm cover and look to the front right side of the mechanics - you'll see a linkage that should turn when you rotate the feed-dog drop control - if this doesn't separate or is permanently separated, whatever you do with the control, you need to give it a drop or two of Bernina sewing oil and gently help it move - once free, that should solve the problem. I cant think of any other reasons !!
Hope that helps !
1helpful
Is there a way to drop feed dogs on My Excel 4023? I thought there was but I seem to have forgotten how to do this. Please help!
The drop feed lever is located underneath the free arm bed at the back. To raise the feed dogs, push the lever to the right. To drop them push it to the left. Hope this helps!
5helpful
2answers
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
