JP930 large right front dual size burner. When you turn on the burner, it stays on HIGH, will not regulate at all regardless of setting. It will shut off when moved to off position. Which part needs to be replaced?
Thanks for any help.
This model number is not complete to get you the right part. Use model number off the cooktop. It will be on the underneath sideThis model number is not complete to get you the right part. Use model number off the cooktop. It will be on the underneath side
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Model # JP930 B0C1BB
