20 Most Recent GE 30 in. JP340 Electric Cooktop Questions & Answers
maybe reason breaker kept blowing was a faulty cooktop
GE 30 in. JP340... | Answered on Nov 07, 2017
yes there is a kit you can use. most diy shops that sell cooker fixings etc will have them. they usually stainless steel and you have to cut them to size you need. and make a square with it. backing with bits of wood to the size of the hole need to put the top on and the stainless steel to cover the wood that has been put in. you can make your own. by filling the hole with wood strips get from a timber yard or store have them cut the size you need. then fix them to the open part you need to fill. leave a lip ( this is to put the stainless steel to. check it all fits. then get the strips of metal to fill the hole making sure they the right size glue them down to the strips of wood you have put in then put the top on. jobs a good one. don't nail the wood in place put 4 good long screws in each piece of wood gives it strength then.
GE 30 in. JP340... | Answered on Oct 31, 2013
Hi, if you still have this stove can you please contact me? Thanks so much!
GE 30 in. JP340... | Answered on Jan 17, 2013
That's the correct way to hook it up. Check the wires for possible insulation missing.
GE 30 in. JP340... | Answered on Jan 07, 2012
Hi glors732,m
A chip perhaps, but not a crack, you will need to replace the whole glass panel. Will be quite expensive though.
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it.
GE 30 in. JP340... | Answered on Aug 09, 2011
HELLO ELECTRIC COOKTOP EXPERT AT YOUR SERVICE
These units has a delay switch which prevents them from turning on and off at certain intervals. To fix your problem, you can easily remove the cooktop from wall power and replace the wall power after several mintues. This will reset the programming and power generated to the system capacitors with fresh power and programming.
GE 30 in. JP340... | Answered on Jan 30, 2011
yes u can just make a call
GE 30 in. JP340... | Answered on Jan 19, 2011
Hi, you can view the manual for the GE Radiant Cooktop HERE
GE 30 in. JP340... | Answered on Sep 28, 2010
GE 30 in. JP340 Electric Cooktop Logo
50 questions posted
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
ge smooth glass electric cooktop model
  • Cooktops
