The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
Testimonial: "There were no filter names in the registry. Img Burn did not recognize CD. Your suggestions were appreciated and helped id a bad drive. Thank you."
I tried the suggestions. There were no names in the registry for any filters. I installed Img Burn, inserted a blank CD and it tried to find it but after a few minutes eventually came back with the message "Device Not Ready (Medium Not Present - Tray Closed)". Thank you for your help.
